Hi I have a zafira B 59 reg what I would like to no is what index code I would need and where would I find the right one
for my car thanks in adv
Printable View
Its a bid screen
have you looked under Zafira, then code index section of the forum?
yes but I don't no witch one I would need as I don't have the part number thanks
so looks like you need to find it out then before you can do anything... take the display out and read the number or use opcom to find it.
how do you ether audio index code I'm sure that I am on Board Computer
008 but my audio wont turn off doing my head in thanks for your reply
so whats the part number? you need that for the right one
When you say wont turn off, you mean not at all?, not with the ignition?
have you been messing with the programming to cause this?
not with the ignition I mess with opcom and got lost
i think this is the part number 13301077
there is a setting in 'settings' on the display itself for ignition logic.
what does opcom show the part number as when you log in to display?
For programming you need to go to display, then programming, then code index
