No worries. I didn't expect that there is loom for sale, ready to be installed.
Will have a look now.
Thanks again!
Printable View
Thanks again!
Thanks for the link. I will have a look and will see about placing an order.
Hello domtorredo,
All clear regarding cables, they are available and no issue here.
I have one more concern:
"Step by step:
2/ Check if instrument supports the Sport switch.
In EPC: An Km/H instrument which supports Sport is a benziner, is with manual gear has the marking of YN or CE .
With Tech2 in the "IPC" "Sport switch" menu: set "Present", this will set the gas/steering wheel reaction to sporty
Cars which have ESP set "Sport chassis" (or sport under-body) , this will allow the switch off of the ESP with continuous 4sec push.
To check if the main instrument supports this functionality check EPC, else perform a physical test"
I have no option to perfom any test with Tech2. I have possibilitty to use Op-Com.
I cannot clearly understand if instruments support Sport switch.
Based on that quote, should I concider that when entering in IPC>Program variant configuration, if Sport Switch drop down menu is selectable and I'm allowed to change config, theb my instruments do support this mode?
If this is not true please advice how could I check this?
Do you have any clue what this physical test means?
What ident clocks you have?
Physical test is meant fit everything and see if it works
Regarding epc there isnt any info if they are for sport mode or noti even no info on cruise control etc
But it can still be checked
Hmm I have to check what the ident is. Will have a look tomorrow and will let you know.
Hope that we will finally get this sorted out.
I believe it would be helphul to other people.
So IPC in my Astra is HE ident. Part number: 13186323
Ok will check so yours is lhd and in km/h?
Yep, it is left hand drive and km/h. Car was manufactured for italian marked.
I hope to hear good news from you, domtorredo.
Cheers,
