hi I have astra h 3 door 1.9 dth last weekend with sport button, cruise control, fog lights,
IPC part no. 13230598 Ident: UQ may help
Printable View
Hi Miroslav and thanks for this information. I believe that very soon it will be very helpful, when looking for new IPC.
At this stage I'm trying to find what is the proper way for programming this Sport mode.
IPC>Sport switch> Present is alredy known. Trying to understand if there are other options, which I should change and in which modules these options are(UEC, REC, Engine etc.)
hi I'm surely must be suitable iPC, sport button and two cables between (post #16)
Hello there. my speed clock code is XA. I have enabled sport mode with no opcom in the list. The sport key does not work. should I change my speed clock?
Hello AresUltio,
Did you add two additional wires between IPC and Hazard switch?
Here you are:
Hazard switch - pin 8 to IPC - pin 41
Hazard switch - pin 17 to IPC - pin 11
thank you for the information manevni0 , I was going to try plugging in the pins today.I could not disconnect the IPC socket. How can I disconnect the IPC socket?
You must pull out the locking at the end of the connector.
https://i.hizliresim.com/jgoBaj.jpg
I disconnected the socket from the IPC but could not open the socket
