I could check if I know what wires am I looking for. Can you provide me with some pin numbers and color of those wires?
I will check and will revert to you.
Printable View
Ok will post them tonight
So at switch
Pin 17 yelow/red wire goes to ipc pin 41
And pin 8 yellow/black wire goes to ipc pin 41
Thanks for quick reply. If pin 17 and pin 8 from switch, both go to pin 41 in ipc, where is the common connection?
Sorry mistaped will check again
Pin 8 goes to 41
And 17 to 11
I have checked the hazard connector and on position 17 I do see pin inside. In position 8 there is no pin inside the connector.
One more question - do you know what is the type of those crimp contacts? And if they are the same from hazard switch end and IPC end?
Looks like I will have to add some wiring.
Well thats why it doesnt work
As far as i remember they are same
Okay so there is improvement. Missing peace is found.
Do you have an idea what is the type of crimp contact, which goes into connector for both sides?
Any dimentions, parameters or part numbers will be helpful.
Must say sorry im not allowed to give this information
Check in peckys shop he should have ready made kit for this retrofit
