Park pilot wiring
Hi all
I’m retro fitting park pilot in my van. But I could use a wiring diagram if anyone has one !.
There’s 2 plugs on the park pilot module I know that one of these is the canbus (only 1 wire in it green) and it goes to pin 29 on the bottom plug on the rec.
The other plug has 8 wires !
Solid black - thinking this is power to the module
Solid brown - thinking earth for the module
Black with white stripe - thinking power to the sensors
Brown with white stripe - thinking earth to the sensors
Then I have
Solid yellow
Yellow with white stripe
Yellow with purple stripe
Yellow with red stripe
Thinking these are the sensing wires but don’t know which is which sensor !.
Also need to know which pin is which on the sensors if anyone knows !.
Thanks in advance
1 Attachment(s)
Here is wiring diagram for you:
