It will be Part Number - that will be the part number.
And what was the code index before you changed it and why did you change it?
Printable View
I changed it so I could get the trip menu like range 300 mile but I didn't see what it was before fools rush in and that
Attachment 2164 I have this picture
Attachment 2165 I have this picture
found it, it is a superceeded part number, being a 2009 manufacturing year i would suggest trying the 008 03 index, the index you have programmed as 010 01 isnt even on peckys list
is this your original display or is this a new one as the code index you have is from an Astra?!
great I will give that a go tomorrow and let you no how I get on thanks for all your help
ps do I need to follow the marrying in for the head unit as I turned of the radio security
its the original display its like that because I was trying anything to try and get it back
there is no need to touch theft protection unless your replacing anything
right I've put it back to 803 and it still does the same thing wont turn off when I take the key out.
iv sent some pictures I have tested the red wire on the audio plug and it stays on with the ignition off
not sure its meant to do that as I think you can leave the rado on for 1 hour after switch offAttachment 2166
Attachment 2167Attachment 2168
