4 Attachment(s)
Astra H 1.8VVT Wont Start F on Dash and OPCOM Results posted
Im really stuck now and hopefully I can get some help off people who have had the similar problem if not I will have to take it to Vaux.
Its a Astra H 1.8VVT Z18XER MANUAL
It all started a month ago when the car wouldn't start and displayed F on dash, I got someone out and they cleared the fault codes and it worked.
Soon after randomly it would try to cut out but no actually die, the lights on the dash and speedo and rev counter would go to zero then back to normal and the car would jerk for that second. Or it would jerk and the traction control light would stay on until the car engine was turned off and no reappear until the fault happened again.
Now again the car just died while driving and would not restart with F being displayed on the dash. I have had a few auto elec's would now to check the car with Tec2. The fault that has come up is no communication with the ECU. The fuses in the engine bay, earth connections all seem fine.
The auto spark has now tried two different ECU that hasn't made a difference, even getting a second hand kit of another car including the ECU, clocks, front and rear fuse box, CIM e.c.t
Attachment 1847Attachment 1848Attachment 1849Attachment 1850
