Yes with ipc is loads of problems on epc they arent listed what extras they have and what not, same with cruise control most of ipc doesnt have led but it still works
will try to source out some ipc idents your car is diesel/petrol auto/man?
Printable View
Found some these are for Park Pilot and Cruise Control, Manual Transmission other extras unknown
For petrol
Part number 13309000 ident YF (idents have been changed PH-XL-UB-YF)
Part number 13309005 ident UM (idents have been changed UX-ZW-UM-UM)
Part number 13309018 ident YT (idents have been changed UY-YT)
In case if someone will need them in future for diesel
same as for petrol Park Pilot and Cruise Control, Manual Transmission other extras unknown
Part number 13309006 ident YG (idents have been changed PK-XQ-UD-YG)
Part number 13309001 ident YB (idents have been changed UZ-ZY-UP-YB)
Part number 13309019 ident YU (idents have been changed BF-UZ-YU)
cant be big difference in never models as if you have car like 2004 and never compatible model with changed ident was relased in 2011 and it works than it should work vice versa too
never paid much attention to these things if anything internally have changed if i need something im checking epc than i know whats is compatible whats not i think pecky could tell bit more if anything is different when idents changes
You are always welcome wish you a luck finding it just if you can post it how things is going can be useful to other members
Will do, I have learnt quite a lot just by browsing through the threads.
yep thats a main reason why forums must be but all depends on users most of them just finds solutions and thats it they dont report if it worked if not and how they fixed things
Hmm, this makes for interesting reading, I have the park pilot module ready to be fitted along with the PP button on my 6 button centre console, I will get my speedo out so that I can check the part number(s) against the ones posted in this thread, Hopefully I wont have the incompatibility issue that the OP has had, mine is a 2008 Astra SRi and as was also mentioned, mine has the LED indicator for cruise control even though my car wasn't fitted with CC from the factory. I'll post back with the results of my findings as I'd quite like to get this retrofitted at some point in the near future
