The centre slides out at the end of the socket.
There is small lock pins.
Printable View
thanks I will try next week.
Good evening. I pulled the cables did not work in the sport mode. does not support my speed clock? What do you suggest ?
Whats the ident written on the clocks, teh two letters.
I can check on my compatible list
Gav
He has wrote that it is XA.
I cant find that one ...maybe same that CA.
If I change the speed clock, does the sport mode work?my car astra h 1.6 115 hp 2012 essentia.don't REC in my vehicle.Which code do you recommend for my vehicle as speed clock?
https://i.hizliresim.com/nbPjmR.jpg
opcom I saw 3 options in codex while browsing ipc menu.the ipc codexs were 2 as far as I know. could it be?
i need ipc idents with sport button.
benzin km/h
thanks
