hi i have a cd70 from a vectra that i have put into an astra but the miles left and the temp do not work but i do not have the code can you help?
Printable View
Are you using the vectra display?
If yes, it is not compatible with the Astra.
The radio has nothing to do with the miles and temp, it is a function of the display. The vectra CD70 is exactly the same as Astra except for the faceplade and code index.
Hi Pecky!
I bought in England D70Navi. It is coded. Seller says - do not know of any code or VIN. No VIN - the dealer does not give the code.
Can you help me?
Yes I can help. There is an eeprom chip inside that needs to be read. From analysing that, the code can be worked out.
That is the only way, there is no VIN stored in the radio, so you cannot get the code from the dealer.
To program into your car, you will need to know your cars security code as well.
Hi Pecky!
Eeprom chip inside read.
http://www.diagnostics.org.uk/pics/?di=TUI2
Here is your code.
Hi Pecky!
Thanks for the code. All is fine, it works.
You're the only one who really helped.
Now we have to find the map of Russia.
Can't help you with the Russia map, glad to have helped with the code.
Hi Pecky!
I bought through Ebay in Spain color display for our CD70NAVI
(OPEL VECTRA CID, Teile Nummer 24461297 Code DB).
Unfortunately, he was coded, and the seller does not know
the code, sorry not tested immediately after purchase.
Can you help me get the code from dump ?
Thanks in advance.
EEPROM dump attach here.
