What is original code index in that BID?
Printable View
That's the problem I did not write it down before I programmed a new one.
What is model year of Zafira?
Zafira b 1.8 petrol 140 bhp 2008 year lift
I think you need another op-com version.
These code index must be 5-numbers.
But when I go to hidden menu is not only 008 which I chose but also 008/03 no I don't see 03 in op-com but it is indeed installed altogether as I see it in hidden menu
I am not sure these 5-number codes but found a video where these used.
Is your display 3-line?
yes 3 line bid
They are afterall 3-digit codes but some version shows code and version together….like 00803.
Still strange that programming does not work.
Till today I had 00803 and changed to 010 and immediately after that I refilled fuel as had two hyphons showing I had little fuel. Suddenly the range of km reised with no delay. Previously, after refilling fuel it took a little more time go learn 'I have more fuel in my tank':p I will give it a try for a few days and than I will test the rest of indexes.
The best way to learn which is correct I needt to find someone with exact engine na display.
