Results 1 to 9 of 9
    Member Mktn's Avatar
    Apr 2012
    Chesterfield
    3
    Astra mk5 van
    Mk5 van clocks/Vxr clocks
    Hi basically live broke my clocks in a mk5 van, so I bought Vxr clocks off eBay but I don't have the security code for them as far as I know they've done 16,000 miles. I'm not really bothered if the milage display Is wrong but I just need them programming in? So the van will start with them. I have the code for my van.
    If I start the engine with my clocks in then swap them everything works including starting and stopping the engine until you remove the key, then it just doesn't start at all.
    Can anything be done? Any help appreciated thanks
      7,430
      Hi, Do I take it you have a petrol van?
      They just need programming to the Van, with the settings changed to the engine type in the van as you wont have a VXR engine. That mismatch will put an Incorrect Identifier received fault code, hence the non starting.
      The speedo is part of the immobiliser system, which is why it does this.
      Apr 2012
      Chesterfield
      3
      Astra mk5 van
      Sorry no it's a 1.3cdti. Is it possible to program my Vxr clocks into it?
      I've managed to sort my clocks apart from the milage display as the ribbon wire has started peeling off, if the Vxrs can't be programmed in is it possible to program my standard clocks to needle sweep, and do everything the Vxrs do ( lights turn on when unlocking and stay on til locked? ) etc
      Thanks for your help it's very much appreciated
      7,430
      It is possible with a bit of programming to get VXR clocks working in a diesel. However your revs will look really odd as you will be redlining at the same revs as before, only on the dial card the needle will only be 1/2 way around.
      With regards to your old clocks, needle sweep can only be programmed on a certain trype of circuit board usually found in 07 or later cars/vans. Then I'm the only person who can do it.
      Not sure what you mean by lights on at unlocking, interior speedo lights should anyway, for exterior lighting, then no astra H including VXR have any settings where unlocking the car turns the headlamps/sidelights on
      If you are only missing some of the mileage display, then place a few pieces of tape or paper ontop of the ribbon on the circuit board and re-fit the white plastic surround which will put pressure on the tape or paper and the ribbon, this sometimes is enough to make the mileage display work again.
      Apr 2012
      Chesterfield
      3
      Astra mk5 van
      Ok, im not really bothered if the needles half way round but the engines redlining... so how much would you charge to program the Vxr dials to my van ? I've got all the steering column plastics off and the dials are loose so swapping them takes a few seconds.
      Thanks slot for the help.
      7,430
      Post a thread in the help desk http://www.diagnostics.org.uk/help/f...hp/1-Help-Desk and I will put a cost together.
      Member RamazanPacar's Avatar
      May 2012
      S.Yorkshire , Rotherham
      7
      Astra H 1.7 cdti 100 bhp
      hi,
      i was just wondering what happen to your clocks? do they works ok? did you fit the vxr clocks at the end?
      7,430
      Re: Mk5 van clocks/Vxr clocks
      I've fitted a few sets of vxr ones into diesel cars, and just needs careful editing of the eeprom
      May 2012
      7
      Hi again,
      I have purchase vxr clocks of ebay and i had a bit of time today try and fit it! unfortunalety they was not unmarried from the car that came off!
      So i couldn't find out if the sport button works or not!
  1. VXR Clocks
    By Gav in forum Astra
    Last Post: 16th January 2015, 09:11 PM
  2. Clocks
    By jace1969 in forum Corsa
    Last Post: 8th July 2014, 11:47 AM
astra h clock removal
vxr clocks to cdti
changing clocks astra h cdti
how do i fit astra vxr clocks to my astra van
vxr swwep clocks astra
how to change astra vxr speedo clocks
astra h clocks
vauxhall astra h speedo milage change
astra h needle sweep
astra mk 5 clock change
changing astra h speedo
astra vxr clocks
if i change clocks on astra h will they need coding
programming speedo astra h
change astra h speedo clock
astra van mk5 modified
vauxhall astra h change clock location
code vxr clocks
astra h needal sweep code
fit vxr clocks astra
vxr clocks for astra h diesel
astra mk4 changed clocks car wont start
astra h speedo change to vxr
enable needle sweep opel
astra clock mk5 howto change time
