Results 1 to 8 of 8
    Member Richard Kerman's Avatar
    Jul 2019
    Grimsby
    11
    MK5 van Sportive
    Astra H UEC version required for auto lights / rain
    Hello guys
    Does anyone know which UEC is compatible for auto lights rain sensor I've retrofit as spec pin54 green fuse 17. I believe without checking unit has power the auto dim rear mirror is working I have been able to enable in the REC but not in UEC does anyone know if I'm missing something or just UEC not compatible many thanks Rich
      VIP+ kadett90's Avatar
      May 2014
      Finland
      130
      Opel Astra H
      Can you see rain sensor option in your UEC but you can't enable it?
      Jul 2019
      Grimsby
      11
      MK5 van Sportive
      That's correct I only just extracted my security code last night with BDM I've wired per spec a few weeks back but wasn't able to enable it without code
      Jul 2019
      Grimsby
      11
      MK5 van Sportive
      I can see it but it's Greyed out in the UEC if that helps
      Jul 2019
      Grimsby
      11
      MK5 van Sportive
      I'm just wondering if means anything to anyone I assumed that it's either not connected via the pin54 green signal wire or the UEC needs update or replacing
      Jul 2019
      Grimsby
      11
      MK5 van Sportive
      More info on Firmware/software UEC & REC
      Quote Originally Posted by kadett90 View Post
      Hi m8 thanks for reply on my first post I've checked the versions quicky and the REC installed is HT and the UEC GR Again I'm not sure that is the problem, but just incase I have access to my donor astra H with UEC GU and REC HF and know the security code. Any info would be appreciated I also have another rain/light sensor GM 13107803 and the new astra j small round ones with same 3pin plug not actually checked it fits yet. If anyone could point me in the right direction would be great
      Thanks Rich
      May 2014
      Finland
      130
      Opel Astra H
      I checked the UEC with my own Astra H.
      It was HC and there you can enable the rain sensor.
      HC,GR and GU should be compatible.
      Have you got Tech2?
      Jul 2019
      Grimsby
      11
      MK5 van Sportive
      Have you got Tech2?
      Unfortunately not I've got Opcom it's always looked after me before I'm using vauxcom v1.45 120309a its let me program before I'll have another look today cheers
  1. Retrofit auto dimming mirror and rain sensor
    By zdravko.primorac in forum Astra
    Last Post: 7th October 2019, 11:59 AM
  2. Replies: 1
    Last Post: 27th October 2017, 02:58 PM
  3. How to programme auto lights Astra h
    By lfcmassive in forum Astra
    Last Post: 24th September 2017, 02:22 PM
  4. retrofitting rain/auto light sensors..
    By corsaedt in forum Corsa
    Last Post: 21st December 2013, 10:00 PM
