    Member MarkoO's Avatar
    May 2019
    Croatia
    14
    Corsa C
    Z12XEP O2 sensor to X10XE
    My wife has a Corsa B with the X10XE engine and a damaged O2 sensor (the one closer to the engine). There is one scrap C with Z12XEP and i would try to put O2 sensor from that engine to X10XE. Is that compatible? They physically look the same and connector seems to be same but is the signal same?
  1. MAF Sensor
    By Ben_Spencer in forum Mechanical
    Last Post: 26th October 2014, 07:53 PM
  2. Map Sensor
    By ANT-VXR in forum Mechanical
    Last Post: 1st October 2012, 06:43 PM
  3. 2128 - Steering angle sensor - Calibration of steering angle sensor not possible
    By pecky in forum Zafira B Technical Service Bulletins
    Last Post: 17th April 2011, 07:48 PM
