Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    VIP+ kadett90's Avatar
    May 2014
    Finland
    119
    Opel Astra H
    GID use pin 12.
    Here is code index for tyres:
    018
    155/80R13
    175/65R14
    185/55R15
    195/45R16
    019
    165/80R13
    165/R13
    175/70R14
    185/60R15
    205/50R16
    205/40R17
    205/45R17
    • #12
      Member lupan bogdan's Avatar
      May 2019
      Brasov, Romania
      4
      Astra Mk5
      Hi, try in the op-com clone Meriva 2006 section ... but you can not change the index code ... just with tech 2.
    • #13
      Member MarkoO's Avatar
      May 2019
      Croatia
      14
      Corsa C
      Quote Originally Posted by kadett90 View Post
      GID use pin 12.
      Thats true for older displays, but newer use 3 and 11 MSCAN... i was asking because there was already wire on 3 going to the old CDR2005, but no wire on 11. Long story short, and to answer myself, it uses both 3 and 11...which means i had to add improvised pin to position 11 in diagnostic connector. My car is 2004 and it did not have it.
      Thanks for the code indexes. I will have to visit someone with tech2.
      Unfortunately that china clone does not have proper codes for Meriva 2006. There is a mix of different codes from Astra and Zafira. All of them dont work properly.
    • #14
      May 2014
      Finland
      119
      Opel Astra H
      Yes both 3 and 11.
      I looked only your cars my. and as you say older use 3.
    • #15
      May 2014
      Finland
      119
      Opel Astra H
      What is the my. of that Compo where is the Gid from?
    • #16
      May 2019
      Croatia
      14
      Corsa C
      I think 2008. Radio CD70 is 2007 and GID 2004.
    • #17
      May 2019
      Croatia
      14
      Corsa C
      Thank you all, it works Today i've been to the Opel dealer and they enabled it using the code index 018 according to my tire size. They gave me that "are you crazy that cant be done on your car" look, but finally they did it.
      So one more time THANK YOU ALL! You are the best.
  1. Corsa D write text on GID
    By digidax in forum Board Computer
    Last Post: 13th January 2019, 09:12 AM
  2. Enabling DRL's - Which Option ?
    By Robsey in forum Vectra
    Last Post: 28th June 2012, 02:17 AM
