Results 1 to 6 of 6
    VIP nicos's Avatar
    Dec 2016
    Liege
    77
    ASTRA TWINTOP 1.9 CDTI 200HP
    Troublesshooting Cd70 with GID Ident BG Astra H
    Hello.
    I retrofitted a Cd70 on a astra H 2008 modelyear.
    Before it was equipped with a Cd30mp3 and a Grafic info display GID with ident BG .
    I know and i see GID are compatible for navigation menu.
    So i keep GID screen , I have put a new antenna and programmation completed with Tech2.
    On programmation display I programmed that my new head unit is cd70/dvd90.
    Everything is well programmed.menu for navigation is on and navi is working.
    Now the problem
    While driving I have the pop up message for example to turn right on 50meters.But the pop up message is blank and blocking navi menu.i must to put on main button to exit.And every time navi tell me to change direction the pop up menu appears and blocking again with this blank pop menu.
    In my research I found that original equipped GID with Cd70 has this navi menu:
    And this is my menu
    The main difference is in my menu I have map menu but GID has not mapping option, only arrows .
    So i think that it must be a way to remove the option map from my menu because GUD screen acting like he has mpps on his menu and when the pop menu to change direction appear my menu blocks.
  1. ASTRA H DISPLAY EEPROM GID 93C66 Siemens VDO Ident SE
    By nicos in forum Infotainment - ICE - In Car Entertainment
    Last Post: 14th November 2018, 10:18 PM
  2. NEED CODE FOR ASTRA H DISPLAY GID Delphi Grundig Ident BG
    Last Post: 28th June 2018, 08:25 PM
  3. CD70 - 24c64 - Siemens VDO - Ident: AE
    By pecky in forum Dump Archive
    Last Post: 13th October 2016, 09:46 PM
  4. CD70 - 24c64 - Siemens VDO - Ident: FK
    Last Post: 22nd May 2016, 12:18 AM
  5. CD70 - 24c64 - Siemens VDO - Ident: LQ
    Last Post: 21st May 2016, 03:34 PM
