Results 1 to 4 of 4
    Member manevni0's Avatar
    Mar 2015
    Sofia, Bulgaria
    176
    Opel Astra Mk5 1.7 DTH
    Astra H TPMS question
    Hello all,
    I have retrofitted TPMS control module and missing wiring on my Astra mk5:
    TPMS Pin 1 - Green - Low Speed Can - X1 Pin 50
    TPMS Pin 3 - Black - Ignition Live - X1 Pin 12
    TPMS Pin 4 - Ground
    I have installed brand new TMPS sensors on the wheels as well. And it looks that I'm facing an issue there. No any reading about temperature or pressure, I'm getting only battery status "Normal" in the Op-com.
    The following errors are stored in the ABS module:
    https://drive.google.com/open?id=1Hz...bjJAuSWPz1MFb-
    https://drive.google.com/open?id=1x5...ssNfcb3JBwZxTd
    Here is the module:
    https://drive.google.com/open?id=1gM...b49_9kX4uFdIZg
    Here is readout from OP-com the TPMS module:
    https://drive.google.com/open?id=1as...f3q9f6yFpt1vKp
    And the connector:
    https://drive.google.com/open?id=1kt...o5izPKQcy51tOS
    Do you have any idea what could be the reason for this behaviour?
    Regards,
    Nikolay
  1. Astra MK5 Quick Heat question
    By manevni0 in forum Astra
    Last Post: 6th May 2015, 07:24 PM
  2. astra h tpms
    By nellynell in forum Astra
    Last Post: 4th January 2015, 11:59 PM
