Hi all!
I can help with sharing new dumps for EHU, DIS etc that are not present in Dump Archive
May be it will be usefull for somebody
Hi all!
Have you got dump for Omega cid on delivery state.
I 100% have dump with known pin but I'll check for virgin
I've check my dump, all with codes not virgin.
But also I investigated the way of divorcing another BID/GID/CID display and compared some dumps form Omega CID, so I think all you need to make dump virgin is to write zeros in 0dc-0e0
Then it shows that code is 00.
Did you already check this solution?
Decoder says nothing else that code 00.
I think it must be say in delivery state.
What I must write between 0DC..0E0 if I want that pin is 0217.
In some reason it won't regonize the first zero.
Found the way to make divorced CID for Vectra 2002-2003. Post your dump from Omega, I think the way will be the same
