    Member homegoat's Avatar
    Jun 2018
    notts
    3
    zafira B 120bhp
    front rad fan not running when A/C switched on
    hi folks
    zafira 08 reg 120 cdti
    switch on A/C, compressor runs, but the front rad fan does not run
    removed power connector from the bottom of the front rad fan, with A/C on & A/C compressor run there is no power to any of the 3 cables in the power connector
    fuses 5 & 6 are ok
    not tested the relays K11, K12, K13, but each one feels warm so I think the relay coil's are energised
    I'm not sure if either the front or rear rad fan work via the engine temp
    tried oncom on the output tests
    A/C relays 1,2,3 but kept getting ECU returns negative (something like that) and then comms lost error
    oncom did get A/C relay 3 to run a fan on the test, not sure what fan it run (front or rear) as I was in the car
    what else can I check
    thanks
      Jun 2018
      notts
      3
      zafira B 120bhp
      for oncom please read opcom
      brain not in gear
      Jun 2018
      notts
      3
      zafira B 120bhp
      tried the tests in the attached pdf file
      T003 = 12volts
      T004 = 12volts
      T005 = fans did not run
      here is where I've stopped
      T036 where is M3B motor ?
      I removed the power connector on the front Rad Fan checked connections from K12 relay socket 87 to the power connector, it feeds the brown/green connection
      I carried out test T036 as if the front rad fan was M3B (not sure if I'm right)
      T036 = 0 volts
      T037 = 0 volts
      T039 = 0 volts says back to T036
      last year I had to remove the fuse box top (not lid, top) as rain water had got into the box (common fault) do you a connection could have came off at that time ?
      Attached Files Attached Files
  1. Under bonnet switched feed
    By bunch21 in forum Astra
    Last Post: 15th June 2012, 10:18 PM
  2. 2757 - Radio DVD800 / CD500 - Can not be switched on
    By pecky in forum Insignia Technical Service Bulletins
    Last Post: 4th September 2011, 01:14 PM
  3. 2757 - Radio DVD800 / CD500 - Can not be switched on
    By pecky in forum Meriva B Technical Service Bulletins
