Results 1 to 2 of 2
Hybrid View
    Member Jamesd15's Avatar
    Jan 2018
    Glasgow
    1
    Zafira b vxr
    Zafira B vxr bi xenon wiring
    Was wondering if anybody could help me , im trying to fit bi xenon headlights onto my zafira b vxr , the drivers side fitted no problem , but when it cane to do the pass side the plug on the car side is small and only has 8 pins , whereas the headlight has a larger plug with iirc 13 pins might be 11 cant remember , does anyone know how i can over come this problem , like a loom adapter or that . Thanks
  2. #2
    Member nskelin's Avatar
    Sep 2011
    cro
    4
    Zafira b 1.8
    Quote Originally Posted by Jamesd15 View Post
    Hi,
    I have faced the same problem.. You'll need to change connector, metal pins are the same as in old small connector, you just need plastic piece.
    At dealership, connector cost around 120EUR, but you can order directly from factory for 2-3EUR..
    I have changed standard headlights to oem xenon, but still not did turning part.. As far as i know, I'm missing some wires from UEC to headlight, and from sensor to headlight. If you have more info please share :-)
  1. Zafira B Towbar Wiring
    By riches in forum Zafira
    Last Post: 28th April 2016, 11:27 AM
  2. Replies: 2
    Last Post: 26th May 2015, 10:10 PM
  3. bi xenon wiring looms
    By ashley55vxr in forum Astra
    Last Post: 24th April 2013, 07:35 AM
