Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Member TotallyMobile1's Avatar
    Nov 2016
    london
    6
    Vauxhall
    Non Starting Zafira
    I have a vauxhall Zafia 1.6 petrol 2005 Changed sim module,ecu ,rear fusebox,front fusebox, cleaned all earths, the car randomly cranks then stops if you pull the ecu relay its resets and might start. codes that stay in the cim u2100 and u2105 .sometimes there is no communication all together on all modules.
    Must someting like abs not send signal. Any thoughts?
      Nov 2016
      london
      6
      Vauxhall
      Helpppppppp
      Does light with spanner flashes on ipc? What you used to program all these parts what you changed?
      Sent from my HTC One M9 using Tapatalk
      Nov 2016
      london
      6
      Vauxhall
      Sometimes but most of the time no. Also I change everything over ecu cim fusebox from another kit same problem.
      Right spanner light means something with immo
      Does anyone programmed anything after ecu cim fusebox replacement? You cant just change them over they needs to be programmed. Have you checked if previous owner havnt had fitted tracker?
      Nov 2016
      london
      6
      Vauxhall
      Right striped the loom. findings on the left piller bottom connection there are 2 sets of canbus wires green and white. one is pluseing signal out to the fuse box.the other dead.
      not sure where it goes to but when i check the cim it has two sets green and white also.dose anyone know of have a shematics on that part of the loom or know ehere the othe pair of can bus goses. The pair of twisted green and white wire gose into the Abs back into the car up towards the dash.
      then im lost please help.
      thanks you
      Will check for you
      This should give you idea how can bus is wired not a best drawing but should do for now
    • #9
      Member nikh667's Avatar
      Nov 2016
      Bodmin
      12
      Astra 1.9CDTi
      Hi hi, first post on here so hopefully I can be of some help.
      A good initial test to carry out on the HSCAN is to measure the bus where it terminates at the diagnostic plug (pins 6 & 14) for resistance. Have it all connected up back together and use a multimeter set to resistance and measure across these two terminals, you should have approximately 60ohms (this means the HSCAN is physically connected together ok, the bus has two of it's control units with 120ohm resistors built into them to prevent signal bounce, if the twisted wires are broken through anywhere, it'll give a different meter reading).
      The UEC has HSCAN wiring passing through it, however the unit itself does not communicate on the HSCAN, something to bear in mind when testing.
      Another area to check, does this vehicle start and run okay if bump started.? I recently diagnosed a starter motor on a Z16XEP Astra for no start - symptoms were that the vehicle would crank two or three times, then stop - after that it would lose communication with the engine ECU and throw all sorts of BUS errors and DTC's. The starter sounded healthy but was drawing too much current through the earth path it shares with the ECM.
    • #10
      Diag socket wont give much as cim is a gateway to rest of ecus and it will give same reading all the time, best to check between nodes.
  1. Starting problem
    By Felton in forum Astra
    Last Post: 21st July 2014, 02:19 PM
  2. starting problems
    By Andy_165 in forum Mechanical
    Last Post: 1st April 2014, 07:14 AM
engine torque not plausible
ecn 160638
zafira fault codes 160638
07 zafira 1.6 error codes p0171. 0201 0202 .0203 .0204 .
zafira pedal test 0171
fault code 160638
2007 vauxhall zafira p1606 engine torque implausible
