Results 1 to 6 of 6
    Member apic01's Avatar
    Mar 2013
    21
    Help with a fault code please
    Just went to fetch some lunch from work and my car wouldn't start just kept clicking. Have ended up having to run back to work! Only managed to do a quick pedal test and it reported back the fault code ECN13602 can anybody clarify what this fault is for me as I can only get on this site on the work computers everywhere else is blocked.
      VIP Gairo's Avatar
      Aug 2010
      Wombourne, South Staffs
      3,060
      Astra 1.9 16v CDTi SRi XP+ Power Red Estate
      What engine Andy ?
      VIP Gairo's Avatar
      Aug 2010
      3,060
      Z12 XEP Z14XEL Z14XEP
      P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-026
      P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-026
      P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-029
      P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-030
      Z18XE
      P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-022
      P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-022
      P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) C-022
      P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) C-022
      Z18XER
      P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-029
      P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-029
      P0136 O2 Sensor Circuit Open (Bank 1 Sensor 2) C-029
      P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) C-029
      Z16LET
      P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) B-038
      P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) B-038
      P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-038
      P0136 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-039
      P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-039
      Z16XER
      P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-027
      P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-027
      P0136 O2 Sensor Circuit Open (Bank 1 Sensor 2) C-027
      P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) C-027
      Z20LEL Z20LER Z20LEH
      P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-023
      P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-023
      P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-027
      P0136 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-028
      P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-028
      Z16XE1 Z16XEP
      P0136 O2 Sensor Circuit Open (Bank 1 Sensor 2) C-026
      Mar 2013
      21
      Z16XER
      z16xer engine any idea what it could be?
      VIP Gairo's Avatar
      Aug 2010
      3,060
      Well none of those appear to be related to anything that would stop you from starting your car to be honest so I'd hazard a guess at your starter or battery maybe ?
      VX3 crew #30 lucas_1691's Avatar
      Sep 2013
      415
      That code could have already been in the system before this problem occured
  1. Fault code no Tech2 help
    By J18BES in forum Corsa
    Last Post: 9th August 2019, 08:49 PM
  2. help with fault code?
    By mull3tt mk5 in forum Mechanical
    Last Post: 28th April 2015, 07:19 PM
  3. fault code RXE
    By mookev in forum Astra
    Last Post: 11th August 2013, 09:14 PM
