Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 3 door grill
    Member Astra08sri's Avatar
    Mar 2013
    140
    3 door grill
    What stops a 3 door grill fitting a 5 door???
      Member thunderpantz's Avatar
      Staffordshire
      11
      Signum 1.9cdti
      Quote Originally Posted by Astra08sri View Post
      What stops a 3 door grill fitting a 5 door ???
      2 doors..... lol
      In all seriousness, i think it's the bumper. I could be wrong though.
      Member crazibrumi's Avatar
      Dec 2012
      Birmingham
      101
      2005 Vauxhall Astra 1.9 CDTI 150
      From comparing mine and adz t8 the 3 door bumper is more pointed in the middle were as the 5 door is more flat
      Member Harpz Samra's Avatar
      Mar 2011
      0
      you can fit a 3 door to a facelift 5
      just requires cutting sum lugs from what iv heard
      Mar 2013
      140
      Quote Originally Posted by harpz_s View Post
      just requires cutting some lugs from what iv heard
      just what i wanted to hear can anyone else confirm this before i buy one
      thanks
      Mar 2011
      0
      just what i wanted to here can anyone else confirm this before i buy one
      thanks
      ask gairo
      he had his vxr grill on the facelift bumper
      VIP Gairo's Avatar
      Aug 2010
      Wombourne, South Staffs
      3,060
      Astra 1.9 16v CDTi SRi XP+ Power Red Estate
      Correct, it will fit but there are issues with fitting...
      1. the 3 door grille is more slanted than a 5 door grille
      2. the fixing positions are different on the slam panel
      3. the washer bottle cover becomes slightly restricted
      4. you'll need to cut or elongate the fixing holes in a 5 door bumper to accept a 3 door grille
      Mar 2013
      140
      cheers Chris
      VIP Gairo's Avatar
      Aug 2010
      3,060
      This is where a 3 door grille sits on a 5 door bumper once modified to fit...
      This is the drivers side mounting lug re-drilled to allow the extra depth of the 3 door grille...
      This is the middle mounting lug re-drilled...
      This is the passenger side mounting lug re-drilled...
      This is the washer bottle cap, slightly restricted but still accessible...
      Looking down on the grille and bumper centre points, its quite a ways forward but still looks alright when fitted...
      Member frostyburg's Avatar
      Jan 2013
      202
      How'd of thought they would be different , saying that my vxr grill is on the wifes car and the lugs fitted the opposite way to hers , right beatch to remove then when i went to do mine it was other way round
  1. Astra MK5 front radiator grill
    By JADAVFC in forum Astra
    Last Post: 30th April 2013, 05:35 PM
  2. 5 door rear seats are they the same as 3 door?
    By stevie 'g' in forum Interior
    Last Post: 3rd December 2012, 11:36 AM
  3. New Grill
    By Adam_SRI in forum Exterior
    Last Post: 14th July 2012, 11:11 PM
  4. Color coding grill 5 door
    By habi in forum Astra
    Last Post: 29th May 2012, 10:47 AM
  5. Astra H - Rear Door loom (5 Door & Estate)
    By pecky in forum Astra H wiring diagrams and connector pinouts
    Last Post: 20th February 2011, 12:14 PM
SEO Blog
AOC, AON, VXR-Online, Insignia-drivers.uk
