Results 1 to 1 of 1
    Removing Centre Console
    1. Disconnect battery.
    2. Remove radio
    Push removal bracket into the openings (arrows) until it engages, press outwards and withdraw radio
    Unclip antenna cable (1)
    Separate wiring harness plug (2)
    - Release and disconnect wiring harness plug
    3. Unclip heating control
    - Unclip 2x clip at top (1)
    - Separate 2x wiring harness plug (2)
    4. Remove panel on instrument panel padding
    - Unscrew 2x bolt (1)
    Unclip panel
    - Separate wiring harness plug (2)
    5. Remove switch strip
    - Release 2x locks (1)
  1. Carbon Wrapped centre console and more .....
    By M_Blue in forum Vinyl Wrapping & Decals
    Last Post: 23rd December 2016, 04:31 PM
  2. Replies: 0
    Last Post: 27th August 2015, 03:51 PM
  3. Double Din Centre Console...
    By Stevie in forum Interior
    Last Post: 30th August 2013, 04:57 PM
  4. Removing AFL?
    By RobertWeaver in forum AFL Headlights
    Last Post: 29th March 2013, 08:49 PM
  5. removing wrap
    By Harpz Samra in forum Astra
    Last Post: 16th February 2013, 03:33 PM
