Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Site Owner pecky's Avatar
    May 2010
    Wolverhampton, United Kingdom
    7,404
    Insignia 2.0 Biturbo 4x4
    Just look on here http://www.diagnostics.org.uk/help/booking/ click a time and fill in the form. Address details are sent automatically once the booking is approved.
    • #12
      Member A1 clutches's Avatar
      Aug 2014
      Wolverhampton
      2
      Corsa D
      Hi Pecky,
      Can you please contact with ref to activating OBC on my Corsa D
    • #13
      May 2010
      7,404
      Quote Originally Posted by A1 clutches View Post
      Hi Pecky,
      It's 30 for a Tech2 session and there is a booking link at the top of the page with the times I can do works.
    • #14
      Aug 2014
      Wolverhampton
      2
      Corsa D
      Thanks for the reply.
      I did try thee booking link but it only offered evening hours
      I work at A1 Clutches at Shareshill and the car is there 8.00 - 5.30 Mon - Fri and 8.30 - 3.30 Sat
      Is there any way you can carry out the work during those times
      Tony 01922 411700
    • #15
      Member Harald's Avatar
      Dec 2015
      Telford
      3
      Astra 1.7 cdti
      Hi, same problem here, 57 Astra 1.7, no BC function, display got time and temp and 2 further lines, should be OK to be activated. How can I get in touch, I only up the M54, J6. Thanks in advance.
    • #16
      1,161
      Please click on the Tab at the top of the page marked 'Bookings' to get through to the area you need.
    • #17
      Member eatmydust's Avatar
      Nov 2018
      Edinburgh
      2
      Vauxhall Corsa D
      Can I ask to list the steps you follow to enable the BC on a vauxhall Corsa D? I have the gid screen and access to tech2.
    • #18
      Member bank's Avatar
      Oct 2018
      Kyi
      12
      Zafira B
      Diagnostics -> Year - -> Model -> Infotaim=nment system -> DIS -> Programing -> Program code index -> set number of index with BC support.
      Diagnostics -> Year -> Model -> Infotaim=nment system -> DIS -> Programing -> Program variant configuration - set "Board computer" to "Present".
      Usually, to enable BC you encrease number of existing index by 1 (as example, set 009 if existing is 008). You also can find correct code index in TIS
    • #19
      Nov 2018
      Edinburgh
      2
      Vauxhall Corsa D
      Quote Originally Posted by bank View Post
      Thanks mate, much appreciated.
      Can you list the steps to enable the cruise control as well please.
    • #20
      Oct 2018
      Kyi
      12
      Zafira B
      Quote Originally Posted by eatmydust View Post
      Why are you so lasy to use google?
      Diagnostics -> Year -> Model -> Engine -> ECU model -> Programing -> Program variant configuration - set "Cruise Control" to "Present"
      Diagnostics -> Year -> Model -> Body -> CIM -> Programing -> Program variant configuration - set "Cruise Control" to "Present"
      Diagnostics -> Year -> Model -> Body -> IPC -> Programing -> Program variant configuration - set "Cruise Control" to "Present"
  1. Corsa D GID Mpg activation
    By hettrick44 in forum Corsa
    Last Post: 26th October 2014, 01:28 PM
  2. corsa d 2013 large display activation ?
    By davetaylor in forum Board Computer
    Last Post: 26th October 2014, 01:19 PM
corsa gid
corsa d gid
corsa d trip computer
corsa d trip computer activation
corsa d bc
corsa d board computer
corsa d bc activation
vauxhall corsa trip computervauxhall corsa d gidvauxhall gidcorsa trip computer activationcorsa trip computervauxhall corsa board computercorsa d no trip computercorsa d gid screencorsa d code indexcorsa gid displaytrip computer on vauxhall corsa 2009vauxhall corsa tech 2 trip computer activationcorsa d navi boardtech 2 corsa dvauxhall corsa d no trip computerCorsa activate range bccorsa active trip computercode index cd30 board computer corsa d
