Results 1 to 4 of 4
Thread: TID to BID
    Member M1keyb77's Avatar
    Sep 2015
    North wales
    5
    Astra h
    TID to BID
    Hi all after looking on here i have found that i can change from my id to a bid. Bought a bid that has been divorced, fitted everything into my car after divorcing my cd 30 and my id. Married the new BID to my cd 30.
    Now i only have opcom I'm not sure what i need to change to make it read the MPG etc.
    All as it shows is instant consumption, i hit the bc button on the cd 30 and it doesn't really do anything.
    Is there a sort of step by step guide or any advice would be great.
    Thanks.
      Member jpbroad1970's Avatar
      Aug 2015
      northants
      208
      Astra 1.6 VVT Elite 2011
      if I remember right you just have to go in and activate trip computer then make sure the code index is correct as per peckys list depending on model (linear resistance/voltage fuel sender for astra h) then should be good to go
      Sep 2015
      North wales
      5
      Astra h
      Hi thanks for your reply it all seems t be working now I press the correct buttons on the stereo! Only thing I noticed is miles left goes up rather than down
      Think mine is 006 code. Astra h sxi
      55 plate
      1.6 z16xep??
      Aug 2015
      northants
      208
      same as mine so yes 6 would be correct and when on a full tank at first it only showed range of 350 miles but now after a few fills it starts at 425 but when on a run will go up to 500 and about 46/47 mpg driven carefully . same engine as yours and year
  1. Undivorced BID
    By DJDC in forum Board Computer
    Last Post: 15th June 2019, 10:46 PM
  2. Astra H BID Range issue
    By Tawe in forum Board Computer
    Last Post: 29th March 2019, 03:22 PM
  3. Meriva A swap TID with GID
    By alexhan in forum Meriva
    Last Post: 10th February 2019, 07:28 PM
  4. BID Range not quite right...
    By Bolter99 in forum Board Computer
    Last Post: 27th March 2018, 11:17 PM
SEO Blog
AOC, AON, VXR-Online, Insignia-drivers.uk
