    Member Foamer600's Avatar
    Jan 2014
    N Ireland
    5
    2006 Vauxhall Astra H 1.7 cdti sxi
    U2105 - CAN-Bus no Communication with ECM (Engine Control Module) (00) - Not present
    Hi folks,i have scanned my 2006 Astra 1.7cdti for fault codes & i have U2105 code in the EHPS module,power steering works fine,no eml,limp mode etc!When i clear fault code & try to program high speed can for EHPS,i get the pop up message "programming failed"! Am i missing something simple,missing a security code or is this looking like an ecu fault? Any help,guides etc would be fantastic!
    Many thanks for any help & assistance.
    Michael.
  1. Astra J - K20 Engine Control Module X1 (LDD or LDE)
    By pecky in forum Astra J wiring diagrams & connector pinouts
    Last Post: 4th September 2011, 01:29 AM
  2. Astra J - K20 Engine Control Module X1 (2H0)
    Last Post: 4th September 2011, 01:28 AM
  3. 2115 - Column Integration Module (CIM) - Engine does not start, P1614, P1616, B3055
    By pecky in forum Zafira B Technical Service Bulletins
    Last Post: 2nd July 2011, 11:00 AM
u2105 - can-bus no communication with ecm
opel meriva 1.7 cdti u2105 fault codeAstra h can bus no communication with ecmwhat is a cause can- bus no communication with ECM for astra 2015opel astra h 1.7 cdti u2105 faultzafira cam bus not communication with ecmCan-bus No communication with ECM(Engine Control Module)astra 2007vauxhall zafira can bus no communication with ecmu2105 no communication with ecmu2105 pas de communication opel cdtiAstra mk4 can bus no communication with ecm
