Results 1 to 6 of 6
Thread: combo fails
    Member welderman's Avatar
    May 2011
    bury
    2
    corsa
    Smile combo fails
    Hi all.
    I have a 53plate corsa combo 1.7di. few months back put new DCU on at rear of engine. cleared all faults trained and runs great......with an exception of the following:
    1. when idle at lights say, it is searching or surging. Revs are up and down from 500 to 800, but does not do this all the time only occasionally? Checked with vauxhall diagnostics and came back no faults, even though it was doing it at the time?
    2. suddenly all lights came on and engine just stopped working, lights went off. Small orange light off a car with a spanner through it. After six attempts van started and drove off ok? just been back to have fault diagnostics (another 85 quid) and it came back again......NO Faults?
    Can anyone give me more info from these please?
    Regards
    Welderman.
      Site Owner pecky's Avatar
      May 2010
      Wolverhampton, United Kingdom
      7,417
      Insignia 2.0 Biturbo 4x4
      Hi,
      Unfortunately, I don't know too much personally about the engine side of cars as I'm not a mechanic.
      Hopefully someone else may be able to point you in the right direction.
      May 2011
      bury
      2
      corsa
      thanks, hope they can help though as its very annoying.
      Member asim595's Avatar
      Jul 2014
      Rawalpindi
      11
      BMW 2010
      You need to repair the engine.
      Member paul9's Avatar
      Aug 2014
      United Kingdom
      110
      Astra H SXi Easytronic 1.6 TP
      Seeing as how this dead thread was revived, I shall stick my oar in. Uneven idle speed is often caused by a faulty Idle Air Control Valve. Check your air filter and intake system for leaks/blockages/damage, then check your throttle body is clean. Finally, check the IAC solenoid valve. Usually, this means check by substitution, unless it is obviously sticking or damaged.
      Member wontmore.ag's Avatar
      Sep 2018
      doncaster
      5
      1.7dti combo 02
      I need to know if I can upgrade the turbo on the 1.7dti had force induction 63mm hard pipes 450mmx200x65 intercooler any ideas told the the isuzu. 3.0 Monterey 159bhp would work any help appreciated [[IMG][/IMG]
      Sent from my SM-N950F using Tapatalk
  1. Marrying cd30 mp3 combo van
    By andycook64 in forum Corsa
    Last Post: 29th April 2016, 01:12 PM
  2. Combo C/Corsa C Eeprom
    By Gav in forum Corsa
    Last Post: 13th December 2015, 09:25 PM
  3. New combo
    By Rob in forum Other cars
    Last Post: 8th April 2013, 08:37 PM
  4. Meriva 1.7cdti fails to start!
    By Coxiej in forum Meriva
    Last Post: 18th September 2012, 10:16 PM
corsa combo faults
vauxhall combo di surging on tickover
vauxhall combo van showing orange light with spanner
dcu vauxhall combo 1.7
