Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
  1. #31
    VIP+ kadett90's Avatar
    May 2014
    Finland
    124
    Opel Astra H
    Yes,the back side of bcm.
    • #32
      May 2014
      Finland
      124
      Opel Astra H
      Was there pin in X11/39?
    • #33
      Member wars1977's Avatar
      May 2019
      Poznan
      22
      Corsa D GSi
      Quote Originally Posted by kadett90 View Post
      Today I had little time. Sunday. Tomorrow I will know everything and write.
    • #34
      May 2019
      Poznan
      22
      Corsa D GSi
      I checked today whether I have a properly connected LIN cable from park to pin 1 in OBD. It turns out that yes and there is good electrical contact.
      I do not know if connecting my LIN cable from the park to the BCM will change something. In the diagrams it is, after all, 1 wire bus and all LIN cables are together?
    • #35
      May 2014
      Finland
      124
      Opel Astra H
      It should work same in OBD pin 1.
    • #36
      May 2014
      Finland
      124
      Opel Astra H
      You still can't get connect to park pilot ecu.
    • #37
      May 2019
      Poznan
      22
      Corsa D GSi
      I think so too. I'm a bit disgusted. A few wires, equipment in the mem workshop, how to do it also basically know. And it still does not work.
      I noticed that when I first switched on the function ECU presence check module in Tech2, Tech2 stated that something changed on the CAN low speed bus, it looks like he found a parkpilot. I confirmed and asked if it was parkpilot. I confirmed that yes, then showed the list of drivers in the car to which parkpilot has to be reported so that they know that such a driver is in the car and communicate with it. I confirmed. The programming process in all controllers is completed successfully. At the end there was an attempt to connect with parkpilot and unfortunately there is no communication every time.
    • #38
      May 2019
      Poznan
      22
      Corsa D GSi
      By the way, what software do you use? I'm asking for the screenshots you put in.
    • #39
      May 2014
      Finland
      124
      Opel Astra H
      When you measure between in park pilot connector pin 1 and 7 do you get 12V.
    • #40
      May 2019
      Poznan
      22
      Corsa D GSi
      so when I measured between pin 1 and 7 I had 12v
  1. retro fit park pilot
    By andyb76 in forum Zafira
    Last Post: 29th February 2016, 05:40 PM
  2. Park pilot wiring?
    By bruce1234 in forum Zafira
    Last Post: 19th September 2015, 08:00 AM
how to instal tpms on corsa d
original park pilot corsa d
tech 2 coding parking module on vectra c
how to check ecu parking corsa d
Installing tpms on a Corsa d
corsa d retrofit switch
corsa parking pilot
corsa d retrofit parking pilot
corsa d park pilot
how to wire park pilot module to vectra c
