Page 1 of 6 1 2 3 4 5 ... LastLast
Results 1 to 10 of 57
    Dashworx Conversions Gav's Avatar
    Nov 2013
    Bristol
    280
    Zafira Tourer & Corsa D
    Retro Fitting Sport
    I want to fit a sport button to my Astra H.
    What is needed?>
    Gav
      Member elioc9's Avatar
      Jan 2014
      Portugal
      62
      Astra H 1.6
      It depends on what tou have in the car. Usually is the sportbutton, and if needed, a compatible speedometer (or odometer, dont know the exact name).
      Then you just need to program that with opcom or tech2
      Nov 2013
      Bristol
      280
      I have the same engine as the 150 with the sport button!
      Gav
      Jan 2014
      Portugal
      62
      Astra H 1.6
      Step by step:
      1/ Check presence of these cables (connector can be found after you remove the Radio, heat control and the middle front. The connector is connected to the unit which controls the door lock/emergency flasher )
      These cables are going to the instruments
      2/ Check if instrument supports the Sport switch.
      In EPC: An Km/H instrument which supports Sport is a benziner, is with manual gear has the marking of YN or CE .
      With Tech2 in the "IPC" "Sport switch" menu: set "Present", this will set the gas/steering wheel reaction to sporty
      Cars which have ESP set "Sport chassis" (or sport under-body) , this will allow the switch off of the ESP with continuous 4sec push.
      To check if the main instrument supports this functionality check EPC, else perform a physical test
      if you want to add ESP in case you dont have you need an abs pump with a specific ident, these are the idents for the pumps that support esp AJ, AL, HB, HJ ,HK, GB, GX. With pump ident BN is the latest pump and it also supports tyre pressure monitoring.
      hope it helps.
      For tpms you need the correct abs pump and esp working, the control unit, 4 tyre pressure sensors, and either a GID or CID screen. Depending on the spec of your car you may need to add three wires.
      Nov 2013
      Bristol
      280
      Thanks, i have ESP, as i looked my VIN up in EPC
      Gav
      Member manevni0's Avatar
      Mar 2015
      Sofia, Bulgaria
      176
      Opel Astra Mk5 1.7 DTH
      Hello Richard, all Opel followers,
      I have two questions regarding retrofittting "Sport" switch in my Astra H 1.7 CDTI 2004 Cosmo.
      I already got the switch on place.
      I do not have ESP, so when activating with OP-Com I will choose option IPC>Sport Switch>Present.
      I do not want to install ESP(for now).
      So how to check for compatibility my IPC?
      What wiring change is needed in order to get this button operational?
      Mar 2015
      Sofia, Bulgaria
      176
      Just a note: "Sport" button has backlight when headlights are on, but it is not operational.
      7,429
      Quote Originally Posted by manevni0 View Post
      I can't help you any further. Your clocks are compatible because the button lights up, that tells me it is programmed and the wiring is present.
      Some cars it just does not work and there are more components which possibly need changing, e.g. engine ECU or something else.
      Mar 2015
      Sofia, Bulgaria
      176
      Hello Richard and thanks for your advice. About button lights up - it has only backlight. When pressing it orange LED in the bottom left corner does not light up. Even after enabling with OP-Com.
      That's why I suspected that some wiring is missing.
      Any advice will be helpfull.
      Did you checked if you got wire from sport button to ipc?
      Backlight doesn't mean all wiring is in place
  1. Retro fitting
    By EdopcBurg in forum Astra
    Last Post: 24th March 2016, 12:01 AM
  2. Retro Fitting Bluetooth
    By Gav in forum Bluetooth UHP4
    Last Post: 29th January 2014, 10:26 PM
  3. Sport button retro fit?
    By stevie 'g' in forum Electrical
    Last Post: 21st April 2012, 10:16 PM
astra h sport button install
astra h esp button install
vectra c sport button retrofit
compatibles speedometers with sport button
astra install sport button
opcom sport button
astra h sports button fitting 1.7cdti
opel ipc series sport
astra h fit sport
astra h retrofit sport button
astra h sport retrofit
opel astra h sport button remove
astra h sport button ipc pin
retrofit sport button astra h
ipc compatibil sport
adding sport buttom astra h sxi
astra h sport button retrofit
www.diagnostics.org.ukhelpshowthread.php2444-Retro-Fitting-Sportpage4
2006 astra 1.6 sxi retrofit
how to activate sport option on vauxall astra h
astra h sport button retrofit with opcom
astra h activate sport button without
sport button connection opel astra h
Fitting sport button astra
