Page 1 of 6 1 2 3 4 5 ... LastLast
Threads 1 to 20 of 115
Forum: Electrical
Post here for electrical system related queries and questions etc.
  1. 1.6 VVT spark plug gap
    Started by Hobgoblin, 14th April 2012 11:12 PM
    1.6, gap, plug, spark, vvt
    15th April 2012, 12:36 AM Go to last post
  2. 4300k or 5000k hid which one?
    Started by paulwhite1987, 19th April 2013 11:11 PM
    4300k, 5000k, hid, one?
    24th April 2013, 07:53 AM Go to last post
  3. ABS light
    Started by apic01, 4th April 2013 09:54 PM
    abs, light
    4th April 2013, 10:26 PM Go to last post
  4. AC Not Working No Power To Compressor
    Started by lfcmassive, 8th April 2018 11:48 PM
    compressor, power, working
    17th April 2018, 11:09 PM Go to last post
  5. Ac relays
    Started by wharton, 24th July 2014 11:49 AM
    relays
    27th July 2014, 12:47 PM Go to last post
  6. AFL retrofit on my estate
    Started by LeeMutz, 20th July 2014 10:11 AM
    afl, estate, retrofit
    20th July 2014, 11:06 PM Go to last post
  7. Airbag light
    Started by Luckett, 2nd March 2013 07:44 PM
    airbag, light
    3rd March 2013, 10:54 AM Go to last post
  8. Alarm fob help
    Started by Felton, 10th June 2014 07:13 PM
    alarm, fob
    11th June 2014, 12:05 AM Go to last post
  9. are these suitable
    Started by Harpz Samra, 23rd January 2013 07:11 PM
    suitable
    27th January 2013, 09:12 PM Go to last post
  10. Astra 1.9 cdti Speedo clocks died
    Started by Gtioboy, 19th May 2017 10:59 PM
    1.9, astra, cdti, clocks, died, speedo
    21st May 2017, 08:42 PM Go to last post
  11. Astra H Bi Xenons Help please?
    Started by TRIGGAR, 10th August 2014 09:08 PM
    astra, please?, xenons
    30th August 2014, 08:35 PM Go to last post
  12. Astra H Bi-Xenon Headlight Washers
    Started by Gairo, 12th March 2014 01:12 PM
    astra, bi-xenon, headlight, washers
    13th March 2014, 12:21 AM Go to last post
  13. Astra H factory alarm fault
    Started by Gairo, 11th April 2014 07:41 AM
    alarm, astra, factory, fault
    15th April 2014, 12:53 AM Go to last post
  14. astra H FOG light HID
    Started by skydiver, 1st December 2012 12:19 AM
    astra, fog, hid, light
    18th January 2014, 11:10 PM Go to last post
  15. Thumbs down astra h foglight issue
    Started by Ginger_Jez, 5th June 2014 05:58 PM
    astra, foglight, issue
    6th June 2014, 04:21 PM Go to last post
  16. Astra h heater control plug wiring
    Started by lfcmassive, 15th September 2017 01:52 PM
    astra, control, heater, plug, wiring
    16th September 2017, 08:15 AM Go to last post
  17. astra h mk5 Alarm going off
    Started by fone_junkie, 20th March 2013 07:44 PM
    alarm, astra, mk5
    19th January 2014, 08:10 AM Go to last post
  18. Question Astra H UEC separate fog light relay
    Started by motorasz89, 18th January 2022 09:53 AM
    astra, fog, light, relay, separate, uec
    18th January 2022, 09:53 AM Go to last post
  19. astra h ver parking sensors
    Started by ash121186, 17th February 2017 02:07 PM
    18th February 2017, 06:08 PM Go to last post
  20. Astra J Changing DRL Lights !
    Started by Slugz, 7th February 2014 05:23 PM
    astra, changing, drl, lights
    3rd August 2014, 02:19 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
