Page 1 of 2 1 2 LastLast
Threads 1 to 20 of 22
Forum: Zafira B Technical Service Bulletins
  1. 2748 - Radio CD30MP3 - Drive problems
    Started by pecky, 4th September 2011 01:20 PM
    2748, cd30mp3, drive, problems, radio
    4th September 2011, 01:20 PM Go to last post
  2. 2579 - Washer system, pump - Without function
    Started by pecky, 2nd July 2011 12:20 PM
    2579, function, pump, washer
    2nd July 2011, 12:20 PM Go to last post
    2nd July 2011, 12:57 PM Go to last post
    2nd July 2011, 12:34 PM Go to last post
    2nd July 2011, 02:28 PM Go to last post
    2nd July 2011, 10:21 AM Go to last post
  3. 2305 - Transmission M20/M32 - Malfunction
    Started by pecky, 2nd July 2011 10:44 AM
    2nd July 2011, 10:59 AM Go to last post
  4. 2275 - Electric windows - Malfunction
    Started by pecky, 2nd July 2011 12:41 PM
    2275, electric, malfunction, windows
    2nd July 2011, 12:41 PM Go to last post
    2nd July 2011, 10:29 AM Go to last post
    2nd July 2011, 10:16 AM Go to last post
    2nd July 2011, 12:32 PM Go to last post
  5. 2188 - Fog lamps - Glass cracks
    Started by pecky, 2nd July 2011 10:09 AM
    2188, cracks, fog, glass, lamps
    2nd July 2011, 10:09 AM Go to last post
    2nd July 2011, 12:54 PM Go to last post
    17th April 2011, 07:48 PM Go to last post
    2nd July 2011, 10:00 AM Go to last post
  6. 2108 - Taillamps / Brakelamps - Failing during driving
    Started by pecky, 2nd July 2011 12:38 PM
    2108, brakelamps, driving, failing, taillamps
    2nd July 2011, 12:38 PM Go to last post
    2nd July 2011, 12:49 PM Go to last post
    2nd July 2011, 02:06 PM Go to last post
    2nd July 2011, 12:29 PM Go to last post
    2nd July 2011, 10:14 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
p2452 zafira
vauxhall zafira fault code p1614
p2452 vauxhall
zafira code p1614
zafira fault code 2452
zafira P2452
vauxhall p2452
zafira p1614
zafira b not starting
vauxhall zafira fault code p2452
zafira b wiring diagram
vauxhall zafira fault code p0234
z13dtj error codes
dtc opel p2452
zafira b wiring diagrams
zafira b non start
vauxhall fault code 2452
zafira b abs fault
opel zafira errore 2452
zafira b diagram
vauxhall zafira 1.6 fault code p1614
vauxhall zafira b non starting
particle filter sensor vauxhall zafira fault code p2452
zafira steering calibration
security code for steering calibration vauxhall zafira
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
