Page 1 of 2 1 2 LastLast
Threads 1 to 20 of 23
Forum: AFL Headlights
  1. Astra H AFL headlights - Bi-Xenon?
    Started by manevni0, 22nd October 2020 08:55 PM
    afl, astra, bi-xenon?, headlights
    2nd January 2021, 09:02 AM Go to last post
  2. Xenon upgrade
    Started by Peterrl, 31st May 2020 10:46 PM
    upgrade, xenon
    31st May 2020, 10:46 PM Go to last post
  3. AFL connectors
    Started by James Dennis, 1st April 2019 01:07 PM
    afl, connectors
    5th April 2019, 09:40 PM Go to last post
  4. MEriva B, AFL headlight washers?
    Started by gazz292, 26th February 2018 01:04 PM
    afl, headlight, meriva, washers?
    26th February 2018, 01:04 PM Go to last post
  5. Astra afl problem
    Started by Fatheed75, 11th June 2017 10:54 AM
    afl, astra, problem
    11th June 2017, 09:14 PM Go to last post
  6. 2011 insignia afl retrofit
    Started by goldpedro, 13th March 2017 11:49 PM
    2011, afl, insignia, retrofit
    14th March 2017, 09:08 PM Go to last post
  7. Wink 2013 AFL Facelift conversion HELP
    Started by baynes, 28th October 2015 11:43 PM
    2013, afl, conversion, facelift
    3rd February 2017, 10:57 AM Go to last post
  8. Headlight washer connections for afl
    Started by Porter888, 14th June 2016 11:44 AM
    afl, connections, headlight, washer
    14th June 2016, 11:44 AM Go to last post
  9. retrofitting original AHL to AFL in Vectra GTS
    Started by azokan, 12th June 2014 02:30 AM
    afl, ahl, gts, original, retrofitting, vectra
    3rd May 2016, 04:53 PM Go to last post
    19th January 2016, 12:37 AM Go to last post
  10. Question AFL & AHL differences?
    Started by Tarek Hosni El Barbari, 12th January 2016 01:13 PM
    &, afl, ahl, differences?
    19th January 2016, 12:30 AM Go to last post
  11. AFL leveling
    Started by cataline, 29th October 2015 07:35 AM
    21st December 2015, 01:00 PM Go to last post
  12. pre facelift to facelift afl's
    Started by kiwi1, 14th September 2015 11:24 PM
    afl'
'&, facelift, pre
    28th September 2015, 09:16 PM Go to last post
  13. Afl wires
    Started by Man all, 6th September 2015 06:50 PM
    afl, wires
    6th September 2015, 11:13 PM Go to last post
  14. Corsa VXR Burg AFL
    Started by andyferriby, 4th June 2015 04:45 PM
    afl, burg, corsa, vxr
    5th June 2015, 09:57 PM Go to last post
  15. Set Bi-xenon on Astra mk5, trouble?
    Started by _kuhi_, 30th January 2015 08:35 AM
    2 Pages
    1 2
    astra, bi-xenon, mk5, set, trouble?
    6th February 2015, 04:10 PM Go to last post
  16. Corsa Facelift AFL
    Started by p-hoey, 8th July 2012 03:30 PM
    afl, corsa, facelift
    13th October 2014, 11:24 AM Go to last post
  17. Non Directional AFL Lights
    Started by Dmoe, 8th June 2014 09:35 PM
    afl, directional, lights
    8th July 2014, 10:41 AM Go to last post
  18. AFL wiring?
    Started by w3rmz, 17th March 2012 08:15 AM
    2 Pages
    1 2
    afl, wiring?
    19th January 2014, 02:32 PM Go to last post
  19. Insignia xenon lights
    Started by iSPARX AJ, 18th December 2013 04:53 PM
    insignia, lights, xenon
    18th December 2013, 09:42 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
vectra c headlight wiring diagram
corsa facelift afl
corsa d afl headlights
afl headlights
corsa afl headlights
corsa afl headlights level
vectra c afl retrofit
corsa d facelift afl
vauxhall vectra aflhttps:www.diagnostics.org.ukforumdisplay.php23-AFL-Headlightscorsa d facelift afl headlightsafl headlights rapairvauxhall vectra c front lights wire colorsopel corsa afl headlightvectra headlight wiring diagram opel astra j afl headlightswiring diagram afl vectraastra mk6 afl headlightscorsa afl wiringcorsa d facelift headlightscorsa d aflvectra afl lightsvectra c headlamp wiring diagramcorsa d facelift head lights front light wiring loom colours on vauxhall vectra
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
