Page 1 of 52 1 2 3 4 5 11 51 ... LastLast
Threads 1 to 20 of 1039
Forum: Astra
Mk1 | Mk2 | Mk3 | Mk4 | Mk5 | Mk6 | Van | 888 | VXR - Astra Chat
  1. astra h tail lamp problem
    Started by saltundal, 7th May 2024 04:49 AM
    7th May 2024, 04:49 AM Go to last post
  2. Exclamation Astra h cutting out when wipers are turned on
    Started by bullxtz, 19th March 2024 09:40 PM
    19th March 2024, 09:40 PM Go to last post
    13th March 2024, 09:21 PM Go to last post
  3. Astra H, Front indicator problems
    Started by DwayneD, 4th February 2024 08:54 PM
    6th March 2024, 11:44 PM Go to last post
  4. Question Installation of audible warning and belt sensor
    Started by franbmx, 28th November 2021 09:24 PM
    audible, belt, installation, sensor, warning
    6th March 2024, 11:06 AM Go to last post
  5. Battery consumption problem diplay CID astra H
    Started by franbmx, 6th March 2024 10:52 AM
    6th March 2024, 10:52 AM Go to last post
  6. Retrofit ESP astra H
    Started by okkie-001, 18th January 2024 07:36 PM
    29th February 2024, 08:37 PM Go to last post
  7. Identify speedometers with all options. (LEDs) Astra H
    Started by Arbe_GTC, 4th October 2023 12:56 PM
    2nd February 2024, 04:40 PM Go to last post
  8. Retrofit ESP astra H
    Started by okkie-001, 18th January 2024 07:37 PM
    18th January 2024, 07:37 PM Go to last post
  9. Question Astra H Interior Color Codes or Paint - Satin Stone
    Started by chrismin13, 10th November 2023 12:12 AM
    10th November 2023, 12:12 AM Go to last post
  10. Leak under Astra
    Started by Mitchastra, 23rd October 2023 04:00 PM
    23rd October 2023, 04:00 PM Go to last post
  11. Error AHL astra h
    Started by okkie-001, 3rd July 2023 06:21 PM
    12th July 2023, 06:59 AM Go to last post
  12. astra j mileage display -----
    Started by tremo1984, 5th September 2016 04:24 PM
    23rd June 2023, 08:16 AM Go to last post
  13. Question Astra H speedometer error (ıpc) help me
    Started by AresUltio, 13th June 2021 09:30 PM
    16th May 2023, 05:24 PM Go to last post
    19th April 2023, 01:14 PM Go to last post
  14. DDS/TPMS once again.
    Started by xsatquest, 11th March 2014 08:48 PM
    16th April 2023, 07:39 PM Go to last post
  15. Ecu pinout Astra h
    Started by muttlydog, 23rd February 2023 09:04 PM
    13th March 2023, 01:14 PM Go to last post
  16. Retrofitting PEPS (Keyless Go)
    Started by icemann3016, 3rd January 2023 03:35 PM
    (keyless, go), peps, retrofitting
    15th February 2023, 06:23 AM Go to last post
  17. Astra J Mileage Showing -----
    Started by m3nt4l, 1st February 2023 06:11 PM
    -----, astra, mileage, showing
    2nd February 2023, 05:27 PM Go to last post
  18. astra h tpms
    Started by nellynell, 9th April 2012 08:01 PM
    23rd November 2022, 02:16 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
p0234 astra 1.7 cutting out
astra diagnostics forum
https:diagnostics.org.ukforumdisplay.php68-Astra
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
