Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 ... LastLast
Threads 61 to 80 of 200
Forum: Vectra
Mk1 | Mk2 | Mk3 | VXR - Vectra and Signum Chat
  1. Nick6425 vectra xp2 estate progress thread
    Started by Nick6425, 9th March 2014 05:30 PM
    3 Pages
    1 2 3
    estate, nick6425, progress, thread, vectra, xp2
    29th August 2015, 12:58 AM Go to last post
  2. Problem with comfort close
    Started by soulman, 14th November 2011 09:11 AM
    3 Pages
    1 2 3
    24th August 2015, 10:32 PM Go to last post
  3. Ecu no communication on opcom
    Started by Tgarrett, 13th August 2015 12:12 PM
    communication, ecu, opcom
    15th August 2015, 12:55 PM Go to last post
  4. bcm change advice
    Started by Alan Ansell, 12th August 2015 06:04 AM
    advice, bcm, change
    12th August 2015, 04:37 PM Go to last post
  5. juddering on acceleration
    Started by karlosantanas, 26th May 2015 06:10 PM
    11th August 2015, 11:22 PM Go to last post
  6. IPC display (not the dial card) KM vs Miles
    Started by soulman, 15th July 2015 11:45 PM
    (not, card), dial, display, ipc, miles
    4th August 2015, 12:54 PM Go to last post
  7. vectra c 08 damaged screen replacement
    Started by steviec, 30th July 2015 12:20 AM
    damaged, replacement, screen, vectra
    31st July 2015, 12:11 PM Go to last post
  8. Advice on vectra c GID code index
    Started by j4m1e, 28th July 2015 07:53 PM
    advice, code, gid, index, vectra
    30th July 2015, 06:24 PM Go to last post
  9. Vectra C Clocks
    Started by Gav, 28th July 2015 04:12 PM
    clocks, vectra
    28th July 2015, 05:40 PM Go to last post
  10. Signum codes
    Started by dave234, 19th April 2015 07:51 PM
    4 Pages
    1 2 3 ... 4
    codes, signum
    9th June 2015, 05:04 PM Go to last post
  11. Question CDC40 removed from Astra fitted in Vectra
    Started by dodgydc, 3rd June 2015 05:34 PM
    4th June 2015, 07:18 PM Go to last post
  12. CD40 Opera removal - lose code ?
    Started by JohnboyVECTRA, 25th May 2015 08:02 AM
    2 Pages
    1 2
    cd40, code, lose, opera, removal
    29th May 2015, 08:19 AM Go to last post
  13. Z22YH ticking cracking noise
    Started by domtorredo, 17th May 2015 02:05 AM
    cracking, noise, ticking, z22yh
    17th May 2015, 07:27 PM Go to last post
  14. Singum 2,2 dti 2004 front fogs not working
    Started by singuma, 16th May 2015 10:34 AM
    2004, dti, fogs, singum, working
    16th May 2015, 10:34 AM Go to last post
  15. Signum - TC/AFL/PAS
    Started by dave234, 1st April 2015 02:08 PM
    2 Pages
    1 2
    signum, tc/afl/pas
    6th May 2015, 05:53 PM Go to last post
  16. Vectra upgardes
    Started by Riggs, 30th March 2015 11:56 AM
    upgardes, vectra
    1st April 2015, 04:24 PM Go to last post
  17. help virginize key fob transponder
    Started by M4NIK, 23rd March 2015 03:13 PM
    fob, key, transponder, virginize
    23rd March 2015, 09:05 PM Go to last post
  18. help program tcm
    Started by M4NIK, 11th March 2015 03:28 PM
    2 Pages
    1 2
    program, tcm
    23rd March 2015, 09:03 AM Go to last post
  19. Fault codes
    Started by hedders, 22nd March 2015 11:13 AM
    codes, fault
    22nd March 2015, 03:32 PM Go to last post
  20. vectra vxr ids light and tc light on..
    Started by Steveyn1, 8th March 2015 06:14 PM
    2 Pages
    1 2
    ids, light, on.., vectra, vxr
    14th March 2015, 10:32 PM Go to last post
Thread Display Options
Order threads in...
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
