Page 1 of 10 1 2 3 4 5 ... LastLast
Threads 1 to 20 of 200
Forum: Vectra
Mk1 | Mk2 | Mk3 | VXR - Vectra and Signum Chat
  1. code for z18xe
    Started by oni3, 26th February 2024 06:21 PM
    26th February 2024, 06:21 PM Go to last post
  2. Vectra c opc -07 ipc code+mileage
    Started by lampinen, 6th March 2017 03:33 PM
    3rd January 2024, 06:15 AM Go to last post
  3. Vectra C Easytronic Issues
    Started by Solenoid, 17th August 2023 11:11 PM
    clutch, easytronic, issues, vectra, vectrac
    17th August 2023, 11:11 PM Go to last post
  4. Vectra C 1.9 CDTI Ecu wiring diagram
    Started by Skirma, 21st September 2021 06:49 AM
    1.9, cdti, diagram, ecu, vectra, wiring
    21st September 2021, 06:49 AM Go to last post
  5. oil leave warning light
    Started by dezwez, 29th December 2020 06:50 PM
    leave, light, oil, warning
    29th December 2020, 06:50 PM Go to last post
  6. Fault codes
    Started by stevesellars, 31st August 2020 02:37 PM
    codes, fault
    2nd September 2020, 01:08 PM Go to last post
  7. Facelift dash lights only when lights on?
    Started by Leegsi, 12th July 2020 09:36 PM
    dash, facelift, lights, on?
    12th July 2020, 09:36 PM Go to last post
  8. vectra c rear heated seats
    Started by GOPAL RAM, 1st November 2019 09:57 AM
    1st November 2019, 03:55 PM Go to last post
  9. Car pass
    Started by killers2, 29th September 2019 10:35 PM
    car, pass
    2nd October 2019, 03:19 PM Go to last post
  10. wanted vectra ipc eprom dump
    Started by Alan Ansell, 11th August 2019 06:29 PM
    dump, eprom, ipc, vectra, wanted
    12th August 2019, 07:57 AM Go to last post
  11. Ayuda xenon vectra c restiling
    Started by rbngn91, 13th April 2019 01:35 PM
    ayuda, restiling, vectra, xenon
    13th April 2019, 01:35 PM Go to last post
  12. P0621-01 Code
    Started by SSXANTI2, 2nd November 2013 01:03 AM
    code
    2nd February 2019, 10:30 PM Go to last post
  13. Signums AFL retrofit
    Started by EdopcBurg, 6th January 2019 08:12 PM
    afl, retrofit, signums
    6th January 2019, 08:12 PM Go to last post
  14. Cid vectra c
    Started by rbngn91, 13th December 2018 06:43 PM
    14th December 2018, 11:29 AM Go to last post
    15th November 2018, 08:01 PM Go to last post
  15. vectra c airbag ecu b1000 ecu fault how fix
    Started by lampinen, 1st November 2018 08:45 PM
    airbag, b1000, ecu, fault, fix, vectra
    2nd November 2018, 06:12 PM Go to last post
  16. Vectra c satnav cd 70
    Started by Scoobycarl, 15th August 2012 07:24 PM
    29th October 2018, 08:23 PM Go to last post
  17. Signum 1.9cdti juddering problem!!
    Started by savi4s21, 28th August 2018 07:28 PM
    1.9cdti, juddering, problem!!, signum
    13th October 2018, 09:00 AM Go to last post
  18. Fog light
    Started by rbngn91, 3rd March 2018 07:20 AM
    fog, light
    13th October 2018, 07:54 AM Go to last post
  19. Bluetooth
    Started by stevesellars, 12th October 2018 05:18 PM
    bluetooth
    12th October 2018, 08:53 PM Go to last post
Thread Display Options
Order threads in...
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
