Page 1 of 52 1 2 3 4 5 11 51 ... LastLast
Threads 1 to 20 of 1038
Forum: Astra
Mk1 | Mk2 | Mk3 | Mk4 | Mk5 | Mk6 | Van | 888 | VXR - Astra Chat
  1. Exclamation Astra h cutting out when wipers are turned on
    Started by bullxtz, 19th March 2024 09:40 PM
    19th March 2024, 09:40 PM Go to last post
    13th March 2024, 09:21 PM Go to last post
  2. Astra H, Front indicator problems
    Started by DwayneD, 4th February 2024 08:54 PM
    6th March 2024, 11:44 PM Go to last post
  3. Question Installation of audible warning and belt sensor
    Started by franbmx, 28th November 2021 09:24 PM
    audible, belt, installation, sensor, warning
    6th March 2024, 11:06 AM Go to last post
  4. Battery consumption problem diplay CID astra H
    Started by franbmx, 6th March 2024 10:52 AM
    6th March 2024, 10:52 AM Go to last post
  5. Retrofit ESP astra H
    Started by okkie-001, 18th January 2024 07:36 PM
    29th February 2024, 08:37 PM Go to last post
  6. Identify speedometers with all options. (LEDs) Astra H
    Started by Arbe_GTC, 4th October 2023 12:56 PM
    2nd February 2024, 04:40 PM Go to last post
  7. Retrofit ESP astra H
    Started by okkie-001, 18th January 2024 07:37 PM
    18th January 2024, 07:37 PM Go to last post
  8. Question Astra H Interior Color Codes or Paint - Satin Stone
    Started by chrismin13, 10th November 2023 12:12 AM
    10th November 2023, 12:12 AM Go to last post
  9. Leak under Astra
    Started by Mitchastra, 23rd October 2023 04:00 PM
    23rd October 2023, 04:00 PM Go to last post
  10. Error AHL astra h
    Started by okkie-001, 3rd July 2023 06:21 PM
    12th July 2023, 06:59 AM Go to last post
  11. astra j mileage display -----
    Started by tremo1984, 5th September 2016 04:24 PM
    4 Pages
    1 2 3 ... 4
    23rd June 2023, 08:16 AM Go to last post
  12. Question Astra H speedometer error (ıpc) help me
    Started by AresUltio, 13th June 2021 09:30 PM
    16th May 2023, 05:24 PM Go to last post
    19th April 2023, 01:14 PM Go to last post
  13. DDS/TPMS once again.
    Started by xsatquest, 11th March 2014 08:48 PM
    16th April 2023, 07:39 PM Go to last post
  14. Ecu pinout Astra h
    Started by muttlydog, 23rd February 2023 09:04 PM
    13th March 2023, 01:14 PM Go to last post
  15. Retrofitting PEPS (Keyless Go)
    Started by icemann3016, 3rd January 2023 03:35 PM
    (keyless, go), peps, retrofitting
    15th February 2023, 06:23 AM Go to last post
  16. Astra J Mileage Showing -----
    Started by m3nt4l, 1st February 2023 06:11 PM
    -----, astra, mileage, showing
    2nd February 2023, 05:27 PM Go to last post
  17. astra h tpms
    Started by nellynell, 9th April 2012 08:01 PM
    8 Pages
    1 2 3 ... 8
    23rd November 2022, 02:16 PM Go to last post
  18. Issue with Astra H Factory Fitted AFL Lights
    Started by TomF, 9th November 2022 09:35 PM
    afl, astra, factory, fitted, issue, lights
    13th November 2022, 10:07 PM Go to last post
Thread Display Options
Order threads in...
p0234 astra 1.7 cutting out
astra diagnostics forum
https:diagnostics.org.ukforumdisplay.php68-Astra
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
