Page 2 of 52 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Threads 21 to 40 of 1038
Forum: Astra
Mk1 | Mk2 | Mk3 | Mk4 | Mk5 | Mk6 | Van | 888 | VXR - Astra Chat
  1. Astra J Lumbar support (poverty spec retrofit)
    Started by EdopcBurg, 21st August 2022 10:05 PM
    21st August 2022, 10:05 PM Go to last post
  2. Astra H/Mk5 Fuel Indicator/ BC Range
    Started by icemann3016, 9th August 2022 12:36 PM
    astra, fuel, h/mk5, indicator/, range
    9th August 2022, 12:36 PM Go to last post
  3. Issue with interior light - Astra H Twintop
    Started by alexveloso77, 5th April 2022 06:18 PM
    astra, astra-h, interior, issue, light, lights, twintop
    19th July 2022, 07:22 PM Go to last post
  4. Astra H (2006)Mk4 Display/GID Questions
    Started by IrishWildCard, 14th July 2022 08:25 PM
    14th July 2022, 08:28 PM Go to last post
  5. Post Free fuse space in REC
    Started by motorasz89, 20th June 2022 11:09 PM
    free, fuse, rec, space
    20th June 2022, 11:09 PM Go to last post
  6. F23 gearstick repair kit - small issue
    Started by Yorg2000, 1st June 2022 11:33 PM
    2nd June 2022, 11:11 AM Go to last post
  7. Trying to find eeprom on astra vxr clocks
    Started by smokeygamer, 11th May 2022 05:32 PM
    15th May 2022, 11:26 PM Go to last post
  8. REC on bench
    Started by Miriada 4344, 17th April 2022 11:52 AM
    bench, rec
    25th April 2022, 06:18 AM Go to last post
  9. B29550 - 000 Ultrasonic Module Malfunctioning
    Started by alexveloso77, 5th April 2022 06:11 PM
    000, astra-h, malfunctioning, module, twintop, ultrasonic
    5th April 2022, 06:11 PM Go to last post
  10. Engine cutting out
    Started by MarkG138, 3rd April 2022 12:49 PM
    cutting, engine
    3rd April 2022, 12:49 PM Go to last post
  11. Exclamation how to install AHL in astra h
    Started by franbmx, 1st January 2021 09:44 PM
    2 Pages
    1 2
    ahl, astra, install
    22nd March 2022, 03:36 PM Go to last post
  12. REC in non REC Astra H?
    Started by Harry34064, 18th March 2022 06:05 PM
    astra, rec
    19th March 2022, 11:41 AM Go to last post
  13. Retrofit auto dimming mirror and rain sensor
    Started by zdravko.primorac, 2nd August 2015 11:42 AM
    2 Pages
    1 2
    21st February 2022, 08:59 PM Go to last post
  14. No power to AC, Astra mk5 h.
    Started by aku, 2nd July 2014 08:00 PM
    5 Pages
    1 2 3 ... 5
    6th February 2022, 07:10 PM Go to last post
  15. opel astra h mileage correction
    Started by lampinen, 4th February 2022 02:56 PM
    4th February 2022, 03:52 PM Go to last post
  16. opel astra h mileage correction
    Started by lampinen, 25th January 2022 04:21 PM
    25th January 2022, 07:37 PM Go to last post
  17. Retro Fitting Sport
    Started by Gav, 1st February 2014 09:22 AM
    6 Pages
    1 2 3 ... 6
    11th January 2022, 07:07 PM Go to last post
  18. Update KS CID TO BN 3 line
    Started by SportiveSE, 25th November 2020 12:43 AM
    cid, line, update
    28th December 2021, 03:09 PM Go to last post
  19. Opel/Vauxhall eeprom chip locations on GID, DAB45, CD30, CDC40
    Started by robb678, 15th November 2021 08:23 AM
    cd30, cdc40, chip, dab45, eeprom, gid, locations, opel/vauxhall
    15th November 2021, 08:23 AM Go to last post
  20. How to retrieve Mechanical key number (MKN)
    Started by robb678, 15th November 2021 08:22 AM
    (mkn), key, mechanical, number, retrieve
    15th November 2021, 08:22 AM Go to last post
Thread Display Options
Order threads in...
p0234 astra 1.7 cutting out
astra diagnostics forum
https:diagnostics.org.ukforumdisplay.php68-Astra
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
