Page 3 of 52 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Threads 41 to 60 of 1039
Forum: Astra
Mk1 | Mk2 | Mk3 | Mk4 | Mk5 | Mk6 | Van | 888 | VXR - Astra Chat
  1. How to retrieve Mechanical key number (MKN)
    Started by robb678, 15th November 2021 08:22 AM
    (mkn), key, mechanical, number, retrieve
    15th November 2021, 08:22 AM Go to last post
  2. How to replace oil sump gasket on Astra H (Z14XEP)
    Started by robb678, 15th November 2021 08:20 AM
    (z14xep), astra, gasket, oil, replace, sump
    15th November 2021, 08:20 AM Go to last post
  3. Question IPC speed needle calibration
    Started by RoyReijn, 30th October 2021 03:09 PM
    calibration, ipc, needle, speed
    30th October 2021, 03:09 PM Go to last post
  4. Exclamation The Cid screen consumes my battery
    Started by franbmx, 12th October 2021 04:09 PM
    battery, cid, consumes, screen
    24th October 2021, 12:04 PM Go to last post
  5. Question IPC in miles after program mileage [ASTRA H]
    Started by Arbe_GTC, 13th November 2020 08:12 PM
    19th October 2021, 05:38 PM Go to last post
  6. 12+ but to cut the power after a while.
    Started by franbmx, 1st October 2021 05:17 PM
    cut, power, while.
    4th October 2021, 11:39 AM Go to last post
  7. Unhappy astra h IPC cluster 13309008 YJ SW7.655 eeprom dump wanted.
    Started by RoyReijn, 14th September 2021 11:20 PM
    astra, cluster, dump, eeprom, ipc, wanted.
    14th September 2021, 11:20 PM Go to last post
  8. Astra F/G idle speed control valve
    Started by Ballzzee, 11th September 2021 12:16 PM
    12th September 2021, 09:39 AM Go to last post
  9. Question Astra H IPC eeprom issue help wanted!
    Started by RoyReijn, 11th September 2021 09:32 PM
    astra, astra-h, eeprom, ipc, issue, opc, vxr, wanted!
    11th September 2021, 09:32 PM Go to last post
  10. Hazard Switch Assembly - Astra H
    Started by EdopcBurg, 26th August 2021 03:42 PM
    assembly, astra, hazard, switch
    6th September 2021, 04:34 PM Go to last post
  11. Question Astra H Folding Mirrors wiring
    Started by franbmx, 18th August 2021 04:35 PM
    astra, folding, mirrors, wiring
    18th August 2021, 04:35 PM Go to last post
  12. Exclamation Positive locked with key astra h gtc.
    Started by franbmx, 18th August 2021 02:13 PM
    astra, gtc., key, locked, positive
    18th August 2021, 02:13 PM Go to last post
  13. astra h wiring diagram
    Started by devilsoul, 16th April 2021 01:10 AM
    16th April 2021, 08:10 PM Go to last post
  14. Astra H Park Pilot retrofit
    Started by vasilik, 3rd June 2013 11:57 AM
    6 Pages
    1 2 3 ... 6
    7th April 2021, 07:25 PM Go to last post
  15. T888 RHM/ Astra 888 progress thread
    Started by T888 RHM, 2nd July 2013 10:42 PM
    7 Pages
    1 2 3 ... 7
    888, astra, progress, rhm/, t888, thread
    28th March 2021, 01:51 PM Go to last post
  16. CDC40 - CID Screens / Pairing info
    Started by M23B, 16th March 2021 10:42 PM
    astra-h, cdc40, cid, info, pairing, radio, screens
    19th March 2021, 02:42 PM Go to last post
  17. u2100 astra h 1.6 58 reg
    Started by micsry123, 18th March 2021 02:05 PM
    1.6, astra, reg, u2100
    18th March 2021, 02:05 PM Go to last post
  18. Park pilot wiring
    Started by SportiveSE, 21st February 2021 04:57 PM
    24th February 2021, 10:55 AM Go to last post
  19. Infotainment Wiring Diagram - Help
    Started by Ant, 30th December 2015 04:37 PM
    4 Pages
    1 2 3 ... 4
    diagram, infotainment, wiring
    22nd February 2021, 10:00 PM Go to last post
  20. Display fusibles, big, gid, cid....
    Started by franbmx, 20th February 2021 10:36 PM
    big, cid...., display, fusibles, gid
    20th February 2021, 10:36 PM Go to last post
Thread Display Options
Order threads in...
p0234 astra 1.7 cutting out
astra diagnostics forum
https:diagnostics.org.ukforumdisplay.php68-Astra
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
