Page 1 of 3 1 2 3 LastLast
Threads 1 to 20 of 47
Forum: Board Computer
  1. Sticky Thread Sticky: Board Computer - Can it be enabled on my car?
    Started by pecky, 3rd December 2011 11:47 AM
    board, car?, enabled
    3rd December 2011, 11:47 AM Go to last post
  1. 34/5000 Change information on the display GID
    Started by bananek, 11th November 2020 02:15 PM
    change, display, gid, information
    20th February 2024, 05:55 AM Go to last post
    18th September 2023, 08:45 PM Go to last post
  2. AH Delphi GID for linear resistance sensor
    Started by motorasz89, 21st March 2023 09:44 PM
    21st March 2023, 09:44 PM Go to last post
  3. Strange problem activating BC on Astra H
    Started by TMHKR, 29th October 2022 07:14 PM
    activating, astra, problem, strange
    30th October 2022, 07:32 PM Go to last post
  4. CID firmware upgrade
    Started by robwilson69, 12th June 2011 09:32 AM
    26 Pages
    1 2 3 ... 26
    14th January 2021, 03:25 PM Go to last post
  5. BID zafira b which index code to program
    Started by harvard, 24th December 2018 11:06 AM
    3 Pages
    1 2 3
    bid, code, index, program, zafira
    12th April 2020, 07:02 AM Go to last post
  6. Astra H BID Range issue
    Started by Tawe, 29th March 2019 02:22 PM
    astra, bid, issue, range
    12th April 2020, 07:00 AM Go to last post
  7. Where to find code indexes?
    Started by MarkoO, 14th December 2019 03:41 PM
    code, indexes?
    16th December 2019, 10:07 AM Go to last post
  8. Corsa D write text on GID
    Started by digidax, 17th December 2018 06:40 AM
    corsa, gid, text, write
    11th August 2019, 08:16 PM Go to last post
  9. Undivorced BID
    Started by DJDC, 9th June 2019 10:58 AM
    bid, undivorced
    15th June 2019, 09:46 PM Go to last post
  10. GID upgrade although it's now gone weird
    Started by Dave-H, 28th August 2017 10:12 PM
    gid, it'
'&, upgrade, weird
    20th January 2019, 03:58 PM Go to last post
  11. corsa d gid bc activation
    Started by adamblack, 27th August 2011 01:14 PM
    2 Pages
    1 2
    22nd November 2018, 11:25 PM Go to last post
  12. BID Range not quite right...
    Started by Bolter99, 27th March 2018 10:17 PM
    bid, range, right...
    27th March 2018, 10:17 PM Go to last post
  13. Astra H GID program variant configuration
    Started by liviu2004, 3rd September 2015 09:30 PM
    astra, configuration, gid, program, variant
    22nd February 2018, 07:57 AM Go to last post
  14. cid into astra 2009 twintop
    Started by mrsiep, 31st August 2017 01:37 PM
    2009, astra, cid, twintop
    31st August 2017, 09:49 PM Go to last post
  15. CID issue after firmware upgrade
    Started by AntVXR, 7th March 2017 08:53 PM
    2 Pages
    1 2
    11th August 2017, 12:10 PM Go to last post
  16. astra h cid ks proplem
    Started by lampinen, 22nd March 2017 06:38 PM
    astra, cid, proplem
    23rd March 2017, 06:26 PM Go to last post
  17. Changing Astra J Trip Computer To Bigger Screen
    Started by Ryan Clapperton, 11th January 2017 08:41 PM
    astra, bigger, changing, screen, trip
    11th January 2017, 08:41 PM Go to last post
  18. Corsa D GID - Broken ?
    Started by ulb, 26th August 2016 03:30 PM
    29th August 2016, 06:11 PM Go to last post
  19. Difference between AS and BC GID versions
    Started by ulb, 10th August 2016 09:52 PM
    difference, gid, versions
    16th August 2016, 11:08 AM Go to last post
Thread Display Options
Order threads in...
vauxhall astra bc no function
CID trip computer activation zafira B
bc no function astra
bc no function
zafira b bc button activation
vauxhall astra h board computer
astra 2012 board computer activation
zafira board computer - No Function
astra h trip computer activation
opel astra h bc no function
boardcomputer opel astra 2011
astra h trip computer timer cdc40
astra-j 2012 activate computer
astra-j computer trip
Zafira 08 computer shows no function
how to get board computer on astra h
opel astra board computer no function
opel astra j board computer
BC no function opel astra
vauxhall zafira bc activate
opel zafira board computer
vauxhall astra on board trip computer
bc button zafira
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
