Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Threads 41 to 60 of 162
Forum: Mechanical
All mechanical related queries and questions etc here.
  1. droplinks...
    Started by Ginger_Jez, 25th May 2013 05:47 PM
    droplinks...
    25th May 2013, 10:48 PM Go to last post
  2. Ecu removal
    Started by DJH, 10th February 2014 08:15 PM
    2 Pages
    1 2
    ecu, removal
    10th February 2014, 10:52 PM Go to last post
  3. egr
    Started by chris97, 30th September 2018 12:05 AM
    5th October 2018, 08:48 AM Go to last post
  4. egr blanking query
    Started by Craigk, 30th March 2015 10:03 PM
    blanking, egr, query
    5th April 2015, 07:31 PM Go to last post
  5. Egr valve
    Started by Low3n, 24th June 2014 05:39 PM
    2 Pages
    1 2
    egr, valve
    30th June 2014, 11:37 PM Go to last post
  6. EGR valve?
    Started by Lee_mack_sxi, 4th October 2013 10:51 PM
    egr, valve?
    5th October 2013, 07:47 PM Go to last post
  7. Emissions light !!
    Started by wharton, 14th January 2013 01:19 PM
    emissions, light
    14th January 2013, 02:36 PM Go to last post
  8. Emissions light but no EML :confused:
    Started by gary k, 15th May 2013 06:12 PM
    :confused:, emissions, eml, light
    15th May 2013, 09:27 PM Go to last post
  9. engine flush worth it??
    Started by paulwhite1987, 4th July 2013 11:51 PM
    engine, flush, it??, worth
    5th July 2013, 11:05 PM Go to last post
  10. Engine Problem
    Started by Stevie, 31st October 2013 10:17 AM
    2 Pages
    1 2
    engine, problem
    1st November 2013, 10:47 AM Go to last post
  11. Engine stops after starting procedure.
    Started by strilen, 8th April 2019 09:27 AM
    engine, procedure., starting, stops
    8th April 2019, 09:27 AM Go to last post
  12. error 1243 SRi Turbo
    Started by Bennybizzz, 20th March 2014 06:00 PM
    1243, error, sri, turbo
    21st March 2014, 07:35 AM Go to last post
  13. Exhaust centre box
    Started by KraZed, 21st May 2014 03:07 PM
    box, centre, exhaust
    22nd May 2014, 12:59 PM Go to last post
    17th January 2013, 08:28 PM Go to last post
  14. FMIC Your views
    Started by ANT-VXR, 28th August 2012 07:19 PM
    3 Pages
    1 2 3
    fmic, views
    28th August 2012, 09:26 PM Go to last post
  15. gates timing belt kit
    Started by ANT-VXR, 29th May 2012 10:09 AM
    belt, gates, kit, timing
    30th May 2012, 04:43 PM Go to last post
  16. Gear stick movement in 1st
    Started by Marv Owens, 1st December 2013 12:17 AM
    2 Pages
    1 2
    1st, gear, movement, stick
    21st February 2014, 06:42 AM Go to last post
  17. Gearbox
    Started by sharky72, 4th December 2013 08:26 PM
    3 Pages
    1 2 3
    gearbox
    9th December 2013, 08:07 PM Go to last post
  18. Gearbox issue
    Started by pipamish, 20th September 2012 07:15 PM
    gearbox, issue
    21st September 2012, 12:27 PM Go to last post
  19. Gearbox oil for a Corsa C 1.8 SRi ?
    Started by Toddyc, 4th October 2012 03:08 PM
    1.8, corsa, gearbox, oil, sri
    19th October 2012, 07:05 PM Go to last post
Thread Display Options
Order threads in...
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
