Page 3 of 19 FirstFirst 1 2 3 4 5 6 7 13 ... LastLast
Threads 41 to 60 of 369
Forum: Infotainment - ICE - In Car Entertainment
CD30 MP3 | CDC40 | CD50 | CD60 | CD70 | CD90 | CD300 | CD400 | CDC400 | Navi500 | Navi600 | Navi800 | Navi900
  1. Sticky Thread Sticky: Display Compatibility chart
    Started by domtorredo, 4th June 2015 10:40 PM
    chart, compatibility, display
    4th June 2015, 10:55 PM Go to last post
  1. cd70 screen (cid)
    Started by baz2011uk, 11th May 2014 01:31 AM
    (cid), cd70, screen
    13th August 2021, 04:36 PM Go to last post
  2. Coolent Temp Info/ After Market HU
    Started by Bluegrass, 15th July 2021 07:13 PM
    coolent, info/, market, temp
    15th July 2021, 07:13 PM Go to last post
  3. Red face TWO EEPROMS CID 93c66 Siemens VDO ASTRA H Need pin codes!
    Started by nicos, 8th September 2018 08:55 AM
    2 Pages
    1 2
    4th July 2021, 07:58 AM Go to last post
  4. Eeprom chip swap
    Started by Micro5, 20th May 2021 07:11 AM
    chip, eeprom, swap
    23rd May 2021, 03:42 PM Go to last post
  5. Corsa D GID after fitting Touch &Connect
    Started by emes125, 23rd March 2021 02:48 PM
    &connect, corsa, fitting, gid, touch
    23rd March 2021, 02:48 PM Go to last post
  6. Talking Device to read eeprom
    Started by franbmx, 4th March 2021 10:47 AM
    device, eeprom, read
    6th March 2021, 09:22 PM Go to last post
  7. Questions about changue display
    Started by albertogarciavides, 1st March 2021 08:58 PM
    changue, display, questions
    4th March 2021, 07:31 PM Go to last post
  8. Gid delta ecu fault
    Started by nosdmax, 1st March 2021 08:53 PM
    delta, ecu, fault, gid
    1st March 2021, 08:53 PM Go to last post
  9. Cd 70 coding
    Started by davidmitch35, 13th January 2021 10:15 PM
    2 Pages
    1 2
    8th February 2021, 12:56 PM Go to last post
  10. cd30 mp3 code please.
    Started by emre42, 25th January 2021 04:47 PM
    27th January 2021, 02:23 PM Go to last post
  11. ASTRA H DISPLAY EEPROM GID 93C66 Siemens VDO Ident SE
    Started by nicos, 14th November 2018 07:21 PM
    4th January 2021, 05:46 PM Go to last post
  12. Demisting buttons not working after LED change
    Started by Typeone, 30th December 2020 01:37 AM
    buttons, change, demisting, led, working
    1st January 2021, 01:30 PM Go to last post
  13. CID KS and code index
    Started by neand3veman, 30th December 2020 08:55 AM
    cid, code, index
    30th December 2020, 08:55 AM Go to last post
  14. Astra h gid code
    Started by nosdmax, 24th December 2020 06:21 PM
    27th December 2020, 12:01 AM Go to last post
  15. Code from cid CID VC
    Started by rafalcool1, 25th November 2020 07:16 PM
    26th November 2020, 04:44 PM Go to last post
  16. EEPROM GID – Delphi Grundig – 25c080
    Started by oni3, 25th October 2020 10:17 AM
    8th November 2020, 08:28 AM Go to last post
  17. EEPROM BID 93c56 Ident AY BOARD INFO DISPLAY ASTRA H
    Started by nicos, 14th August 2017 10:14 PM
    6th November 2020, 09:18 PM Go to last post
  18. Question possible to add aux to CD30 with adapter and reprogramming?
    Started by enjjayy, 4th November 2020 02:11 PM
    adapter, add, aux, bid, cd30, reprogramming?
    5th November 2020, 11:53 AM Go to last post
    3rd October 2020, 06:12 AM Go to last post
  19. Bid 13208089 ident AT
    Started by oni3, 11th August 2020 06:09 PM
    11th August 2020, 08:16 PM Go to last post
Thread Display Options
Order threads in...
cd70 navi update 2013 www.diagnostics.org.uk
salakala cdc40
SEO Tools
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
