Close
Results 1 to 7 of 7
    Member
    cheshire
    3
    steering angle sensor callibration
    My car came up with the code for steering angle sensor with the esp light 0n the dashboard, took it to vauxhall to have it recallibrated, they said the secruity code woudn,t work, so presuming they got a new one they then said the recallibration didn,t take the light of. Does it need to be driven to take the light of after callibration cause they now say i need a new cim.
  2. #2
    6,845
    I guess vauxhall need to read their own bulletins then
    http://www.diagnostics.org.uk/help/s...ode-impossible
    Has the steering wheel been off for any reason? Would be unusual for this to happen out of the blue.
    Could happen if the car has had clutch or gearbox work as the steering collumn would be disconnected.
  3. #3
    Member
    cheshire
    3
    yes had the clutch replaced and the steering rack fell of the colloum
  4. #4
    6,845
    Assuming the steering angle sensor is back in the correct physical position, take the battery off as per the bulletin in the link
    You need to be careful with an off position steering angle sensor as the ribbon cable in the CIM can snap which then means a new CIM is required.
  5. #5
    Member
    cheshire
    3
    does the car have to be drivan once the sensor has been recalebrated for the esp light to go out
  6. #6
    Member
    May 2014
    nottingham
    1
    similar steering position sensor astra h 2006
    Hi I have a very similar problem with the steering sensor, snapped ribbon during a clutch flywheel replacement changed ribbon but need to re-calibrate. can this be done WITHOUT a tech2 or whatever a garage may use? any help much appreciated
    kyle
  7. #7
    Member
    Jan 2015
    Portugal
    1
    Im having the same problem. But my car went to change Timing belt.
    Could the error been caused by this intervention?
  1. C0710 Steering Angle sensor
    By Scott McGregor in forum Zafira
    Last Post: 17th February 2016, 03:00 PM
  2. Replies: 5
    Last Post: 23rd May 2013, 10:32 AM
  3. steering angle sensor.
    By caza in forum Astra
    Last Post: 5th May 2013, 06:48 PM
vectra c steering angle sensor
astra h steering angle sensor calibration
vectra c steering angle sensor calibration
vectra steering angle sensor
zafira steering angle sensor
astra steering angle sensor
vauxhall vectra steering angle sensor
vauxhall astra steering angle sensor
steering angle sensor vauxhall vectra
steering angle sensor vectra c
vauxhall steering angle sensorsteering angle sensor astra hvauxhall zafira steering angle sensorsteering angle sensor vauxhallsteering angle sensor vauxhall astrasignum steering angle sensorastra h esp lightsteering angle sensor vauxhall zafiravauxhall vectra - steering angle sensorvauxhall vectra c steering angle sensorvauxhall astra steering angle sensor calibrationhttp:www.diagnostics.org.ukhelpshowthread.php672-steering-angle-sensor-callibrationvauxhall zafira steering calibrationvectra c steering calibration
