Close
Results 1 to 6 of 6
    Member
    Sep 2013
    Birmingham
    5
    Angry Astra h 1.7 diesel fault code Ecn 068302 or P068302 Glow plug open circuit
    Hello,
    I have a Astra 1.7 diesel 2009, having problems with the car/ spanner light. Light comes on from cold and stays on until car is turned off and warm around 10mins, can turn off and restart immediately and light is out.
    Have codes Ecn 068302 or P0683 believe these to be Glow plug open circuit.
    Checked glow plugs all working.
    Checked wiring to plug caps and 3 give a reading of 0.5 ohms the other 1 gives a zero reading.
    Checked continuity on zero reading cap has far back down the loom has I can and all is fine .
    Should all caps give a reading of 0.5 ohms.
    Have change glow plug module with no change
    Car has had 3 code readers read it and no faults found, got this code from pedal test, and after checking has above think this is related.
    Any thought would be appreciated has this is driving me mad.
  2. #2
    6,400
    Are you sure that is the code?
    There is a P0638 which is throttle control
  3. #3
    Member
    Sep 2014
    Portsmouth
    2
    I also have the same problem, have read the fault with Op-Com and can confirm it is P0683 Glow Device General Error. I have replaced the relay and the plugs, with new GM parts, and the same fault occurs. When the vehicle warms up and is stopped and restarted, the spanner light goes out and the fault becomes flagged as inactive.
    I'm not sure if it's relevant, but the coolant temperature sensor is reading about 8 degrees high. Just thought I'd mention this for completeness.
    Spend 8 hours replacing the parts yesterday to find the fault occured as soon as I reconnected the battery!
  4. #4
    Member
    Nov 2014
    United Kingdom
    2
    Have you now sorted the problem Nik? I have fault code 068302 on my Zafira and would appreciate any advice.
  5. #5
    Member
    Sep 2014
    Portsmouth
    2
    Quote Originally Posted by Tad T View Post
    It took a while but yes, I've solved it. I ran my own cabling from the glow plugs to the glow plug control relay, as it was too much like hard work to strip the loom for a fauly that might be there.
    It worked a treat. No more problem.
    From what I've read, the engine loom seems to be a little prone to faults. Not a comforting thought!
    Best of luck,
    Nik.
  6. #6
    Member
    Nov 2014
    United Kingdom
    2
    Cheers Nik
Ecn 068302
ecn 68302
ecn 68302 opel astra h
p0683-02
ecn 68302 astra h
p0683 opel astra h
p0683 astra
OPEL P0683
glow plug wiring diag opel astra h
astra diesel faults
P068302p0683-02 opelp0683-02 zafirap0683 vauxhallEcn068302p0683-02 astra hfault code p0683ecn 68302 astravauxhall fault code 68302ecn 68302 opelcodice errore 068302 opel astra hvauxhall fault code p0683astra H glow plug circuit faultecn 68302 zafiraecn 0683
