Close
Results 1 to 4 of 4
    Member
    Apr 2013
    North Yorks
    4
    Zafira B fault code p2279
    Hi
    Please can anyone offer some assistance on this one?
    I have the above fault code & was experiencing a lot of power loss under 2,000 rpm. I replaced the egr valve but the emissions light is still on. A mate then cleaned the vacuum / boost sensor & cleared the fault. After a test run the car was running great but the following day the car stammered once or twice at low revs & brought the same fault up.
    Would you recommend replacing the vacuum / boost sensor or is there something else causing this?
    Thank you.
  2. #2
    6,365
    Have you checked the swirl flap rod is still in place.
    If you take the plastic engine cover off you can see it towards the top of the engine.
  3. #3
    Member
    Apr 2013
    North Yorks
    4
    1.9 cdti p2279 fault
    Checked flaps and link rod all ok actuator is working my mate did test using op com one thing that did happen was the emissions light went out when he manually actuated the flap solenoid with laptop
  4. #4
    Member
    Apr 2013
    North Yorks
    4
p2279
vauxhall zafira fault codes
p2279 fault code
vauxhall fault code p2279
p2279 opel zafira b
p2279 zafira
p2279 vauxhall zafira
fault code p2279
zafira fault codes
p2279 vauxhall
p2279 opel
vauxhall zafira fault code p2279
zafira p2279p2279 astraopel p2279vauxhall code p2279p2279 opel zafirap2279 zafira bp2279 zafira 1.9opel zafira p2279vauxhall zafira diesel fault code p2279fault code 2279zafira b fault codesvauxhall p2279 fault codeopel zafira b p2279
